my 1978 f-250 THE TANK
#31
#34
#35
well the water pump took a crap last weekend. when the engine swap was done the lower radiator hose rubbed on the powersteering belts. bad news is the hose has no part numbers on it. tryed a few of the flex style hose but they hit the belts to. should be fun to try and figure this one out.
#36
havent really shared much about my truck here do to time and my crazy *** job. so here it is in all its glory after a few little projects today.
here a side veiw
got the grill painted and the hoodordament on
a closer picture of the duck
got the fireputter outer mounted and in along with the maglight holder
and just a few radom shots ive been building this thing for awhile even before i found this site. its set up to be ready for anything and everything. i want a d60 for the front the i will tackle gears and a locker.
heres how i got my lights set up on the headache rack
its not perfect but it does what i need. the cab is junk lots of bondo and crappy work[some of my own] been looking around for a cab but no luck yet. thanks for looking.
here a side veiw
Sweet truck that does what you need.
#38
you say you need a cab/front clip ? I have a yellow 77 F-150 2wd im parting out. front clip is cherry, cab has a small hole the size of a pencil eraser in the floor from the drivers heel. long bed is in very good shape, rear end is a 9" with 3.50 gears, open diff, big bearing 31 spline axles. hood is cherry too. ya interested ?
-chris
-chris
Aaron-71
237
01-24-2018 08:32 AM
bjmayberry2
05-07-2015 10:27 PM
dohc_chump
28
07-19-2011 03:01 AM
