1969 F-250 Ranger, Camper Special
ND - i found a good set of used wheels off a late 80's F-250, but I'm wondering if an older (69-77) set of outie hubcaps like these 67 1968 1969 1970 1971 1972 Ford truck Painted Hubcaps Vintage original Dogdish | eBay
will work on these later model wheels?
Are they for F100's or F250/350's? Look exactly the same, except the F250/350's are deeper and larger in diameter.
If 11 3/4" diameter (F250/350), hubcaps will fit. These were also used on 1969/74 E300's & 1975/77 E250/350's.
Sweet, hopefully I can pick up a set soon. I cleaned up the wheels yesterday and repainted them. They look great, but I really want to have the completely stock look with the hubcaps.
So I'm considering doing the whole power steering/disc brake conversion. I've read all the threads and tech articles here - https://www.ford-trucks.com/forums/1...mpilation.html
as well as a recent thread where ND pointed out the differences in the column length even for Bendix steering boxes. Any thoughts and advice before I head down this path are appreciated. There is a donor 1974 truck available now with all the parts but I have not determined which style steering box it has yet. They yard said they would sell me the entire front suspension, disc brakes, proportioning valve, power steering equipment etc. for $200.00.
Norm
Norm
Bendix P/S: 1966/68 F100/250 2WD / 1969 F100/250 2WD before serial number G30,001.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number G30,001 / 1970/79 F100/250 2WD & F350.
1974 F100/250 2WD & F350 will not have Bendix P/S, that's for darn sure, when you consider that 1969 was the last year it was used.
If you need Bendix gearbox parts, where will you get them? There are a few master seal kits available NOS, but nothing else is.
Ask for Bendix parts in chain autoparts stores, most parts clucks won't have a single clue, since last used 43 years ago.
#29
The steering is my biggest concern as you can see in my earlier posts. It is very sloppy and tends to float around a bit on the freeway. Too much or too quick input on the steering wheel can lead to an abrupt lane change. I was considering a power steering conversion. I'm not sure that is worth the effort though and may just follow ND's advice to fix up the stock suspension and manual steering.
abyars111 - I can get a Saginaw box pretty easily since the 1974 truck at the local wrecking yard must have a Saginaw box. I was just hoping to avoid having to modify the steering column. But since it sounds like that is unavoidable, I'm leaning towards leaving it alone for awhile and see if the manual steering really bothers me that much.
#30
