How to test my neutral safety switch - Ford Truck Enthusiasts Forums
Old 09-11-2002, 01:27 PM
cpnhgnjnky's Avatar
cpnhgnjnky cpnhgnjnky is offline
cpnhgnjnky is starting off with a positive reputation.
Old 09-14-2002, 05:10 PM
Phrappster Phrappster is offline
Phrappster is starting off with a positive reputation.
I saw this post about the E4od:
"My truck did the same thing. I'd be driving down the freeway doing around 70 and the tranny would shift to neutral then slam back in. It turned out to be the sensor on the side of the tranny. I can't remember what they called it, something like neutral safety switch or something like that. I do know it only cost like $45.00 "
I have a 91 E250 with the E4od and I was thinking the shudder I get at around 60k's was the torque converter slipping, I've tried replacing all the fluid and filter a couple of times but no success.
But, I did get the code for the neutral saftey switch a few times and now I'm wondering(hoping) that it may have something to do with the problem....so, how do I check it?? I have a good meter and lot's of time!
Thanks for any help.
Rod
Old 09-14-2002, 05:39 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
I think the post you found is for the manual position sensor. I think the neutral switch is actually on the steering column, however I've never had any trouble with it. Shift your truck into park or neutral and then try to start it, it shouldn't start. If it does, you've found it.
You found a code for the nuetral safety switch? I didn't think there was one.
Old 09-14-2002, 05:52 PM
Opps, guess I read that post wrong.
The code I got was: 67 Neutral drive switch sstem fault/PNP switch open
What is this???
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 10:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 07:56 PM
Tags
1987, 2003, 91, escape, f150, f250, ford, manual, neutral, safety, swich, switch, test, testing, testinh, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
