73/77 Steering Wheel on 78/79 Column
Ok, reread.
My opinion is unchanged. The flaw is in the pins they use for the signal canceling not staying in the holes in the adapter and the the holes in the plates and adapter were off just enough to make it a gigantic pain to assemble.
Maybe I just got that one adapter that was slightly off.
I realize there are thousands of these on Fords...just not on mine.
I put a Grant wheel on my '76 and while not the ideal solution, its ok. The good thing is the pins worked fine at canceling the TS, the bad is the horn works sporadically and the horn button likes to pop off at times. It had a later model wheel on it and it didnt look out of place but the horn didnt work and the canceling cam was missing.
I wanted to put a real nice 79 wheel i had on my 73, but the horn and signals don't look to be a match. So i'm stuck with using the damaged 73 wheel until i change the complete column out later this year. I had a grant wheel in another vehical , it was crap , originals are better.
spikinfool05
11-04-2012 07:08 PM
jeff14346
03-09-2012 09:01 AM
jkhaltom
02-26-2003 12:16 PM
