A/C Compressor Belt Squeal
Hey guys,
New to the forum and to diesel trucks. Been wanting one for years and finally got my hands on a 2001 F250 Crew Cab Long Bed 7.3L PSD. Completely stoked.
So anyway, I just bought this thing last week. All has been great with it, except today. I hopped in and fired it up, only to hear a squealing noise. I popped the hood and its coming from the A/C compressor (the clutch was not engaged.) I kicked the A/C on, so the clutch kicked in and the pitch of the squealing changed. The intensity of the squealing correlates with engine speed.
My first thought was the clutch going. I have had this problem in a previous car. I have read a couple threads on here about replacing just the clutch. Seems pretty straight forward.
Could it be just the serp belt. It looks it half decent shape.
How do I decipher between the clutch or the entire compressor?
When the A/C is off, the clutch spins on the bearing. With A/C on the bearing doesn't spin at all, but the compressor internals are moving. The clutch will make no noise while operating.
I suspect the belt. A slightly glazed belt can squeal. Engaging the A/C clutch puts a different stress on the belt, which may make it pull tighter on the upstream pulley, and change the sound of the slip.
I'd change out the belt, and keep the old one as a spare in your parts kit ion the back.
When the A/C is off, the clutch spins on the bearing. With A/C on the bearing doesn't spin at all, but the compressor internals are moving. The clutch will make no noise while operating.<br />
<br />
I suspect the belt. A slightly glazed belt can squeal. Engaging the A/C clutch puts a different stress on the belt, which may make it pull tighter on the upstream pulley, and change the sound of the slip. <br />
<br />
<br />
<br />
<br />
So if the belt is glazed it could squeal at any one certain pulley. I.e. the ac compressor?
While you have the belt off check all pulleys! Pull in and out and wiggle side to side and spin them to make sure they are all smooth and free of play. Also your belt tensioner could be weak also. Mine did the same as yours and mine was solved by a new belt. It would be a good time to change your radiator hose to a dual alternator hose that goes around the belt.
Since the Radiator hose for DUAL ALTERNATOR has been mentioned two times now, does anyone have a ford part number for that item? I want to do that to mine. Aftermarket hose or FORD part for that hose?
To the OP, nice to see your noise dissapear. Great job saving yourself some money doing it yourself and learning more about your truck.
Dwayne
