1987 F-150 Brakes
1987 F-150 Brakes
Okay. This should be a simple one. I have a 1987 Ford F-150. It was built in 2/87. So, in theory, it should use the 1 inch bore master cylinder. I have found the only difference between the 1 inch and the 1-1/16 inch MC is the bore. Why Ford continues to list the 1 inch MC is beyond me.
I have replaced the rear wheel cylinders, rear brake shoes, and rear drums. The rear drums were a mess and the right side wheel cylinder showed evidence of leaking. So I replaced the whole kit and kaboodle. I figured if one side was bad, the other was not far behind.
The front calipers, pads, and rotors appear to have plenty of life.
I have purchased a power bleeder that uses a pump to pressurize the MC and force the fluid through the system. After replacing the wheel cylinders, I tried my new gadget. From the rear wheel cyclinders, I continue to get very fine air bubbles out of the system. I have inspected and found no leaks anywhere, but I am suspicious. THE MC has been replaced with the "correct" 1 inch unit.
WTF? Why am I getting all these fine bubbles? The pedal goes down about halfway before the brakes are affective. I can pump the pedal once and the brakes are firm. It acts like a bleeding problem, but I can't get rid of these fine bubbles. I am considering replacing the entire brake line system with a SS brake line system and replacing both calipers, pads and rotors.
Any direction?
Any direction?
I have the same problem in my 88'. I read on this website along time ago that there is a bleeder screw on the ABS actuator mouted on the frame rail. I guess air can get stuck in this actuator and needs to be bled off. I never got around to trying this myself becasue the truck is no longer a DD and just sits in the shed waiting for me to start working on it.
stangfan78
11-08-2009 01:10 PM
tcd5834
01-07-2007 06:48 AM
