1997 460 torque upgrades - Ford Truck Enthusiasts Forums
Old 09-01-2012, 09:37 PM
Ronnie Fierro Ronnie Fierro is offline
Ronnie Fierro is starting off with a positive reputation.
I've posted a thread similar to this for fuel mileage but now I just want some more torque. 1997 Ford F-250 XL HD, 7.5/460, 4X4, E4OD automatic transmission. Everything is bone stock on this truck. There is no exhaust system after the cat converter, thinking about putting a stack or a straight pipe. But if I could get some suggestions how I can gain some more torque for a low price, that would be great. Thanks.
Old 09-02-2012, 12:38 AM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Basic "cheap stuff" would be headers, high flow cat and bump the ignition timing to 12* base.
These EFI 460s are pretty choked up and if you want much more than an additional ~40HP or so, you're going to need to look into head port-work and aftermarket camshafts. But by that point you're pushing the capabilities of the stock EFI system unless you have a mass-air truck.
Old 09-02-2012, 12:56 AM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
The best torque increase I got with my 86 F250 4x4 460 C/6 was to advance the cam 4 degrees past TDC. I used a Cloyes roller three way timing set. I was amazed. I had 19 inches of vacuum @ idle. The second was a Hughes Towing HD converter.
Craig
Old 09-02-2012, 04:43 PM
BrianDguy BrianDguy is offline
BrianDguy is starting off with a positive reputation.
The later EFI models use a 'straight up' timing set, unlike the carb models, making that mod unneeded.
2002 F350 7.3 intermittently wont start HayTruck 1999 - 2003 7.3L Power Stroke Diesel 16 09-29-2015 10:59 PM
my very first Ford......really itselliot New Member Introductions 4 11-20-2014 02:04 AM
Door Glass Rich56 Ford Truck Parts for Sale 2 09-02-2014 03:40 PM
2000 f250 7.3 lost power mrk28645 1999 - 2003 7.3L Power Stroke Diesel 13 06-24-2014 05:48 AM
1997 460 torque upgrades Ronnie Fierro Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 09-01-2012 09:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
