should i replace torque converter?
Old 08-18-2012, 04:26 PM
RockWVU's Avatar
RockWVU
RockWVU is offline
Doing a mild rebuild/refresh on my 86 460 c6 4x4 in my f350 dually.
should i upgrade the converter while the motor is out? it has 130k on it, but seemed to shift ok.
Should i go with a stock one from say NAPA or do i need something for an RV or performance from summit, etc?
Thanks
Old 08-31-2012, 09:41 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Not sure if you've finished this project but if not, I'd at least buy a premium stock converter. You're all apart, the old converter is still good, but they do wear out.
An upgraded one for towing will be a noticeable gain as well.
Old 09-03-2012, 07:00 AM
fasthauler's Avatar
fasthauler
fasthauler is offline
I am not sure if I would worry about it if it’s working Ok. I replaced my stock unit with the TCI 443630 in an effort to stop tranny overheating and didn’t notice any difference in performance over the stock unit. I would put a heavy-duty converter designed for towing if you do plan on replacing it. I put the TCI in mine and they run around $295.00. You can get a good one from monstertrans.com for $214.00. Their part number is PP3682. That’s only about $50.00 more than a stock unit and I feel it would be worth the 50 bucks to know that you have a really strong unit in the truck. Just my opinion.
03-14-2017 09:19 AM
M-S-G
01-05-2015 07:58 PM
Fordboy49
Aerostar
12-15-2008 09:27 AM
lvseicsh
09-11-2006 10:17 AM
RC Dan
08-13-2005 02:51 PM
Quick Reply: should i replace torque converter?
