Which Wiring Harness to use?
I suspect you may have a broken wire at the buss connection, or the buss bar itself is cracked given the intermittent nature of the problem and the fact that moving the fuse box restores power. It's also possible the main fuse is not making a proper connection or is faulty. Intermittents are always the worst electrical problem to diagnose. Yes, your problem should be shared, but I wouldn't condemn Easy wiring just yet. Given how many of us have used their harness and not experienced any problems with it that I have to give them the benefit of the doubt. They don't cut corners in their harness, it's always possible that a bad component comes along once in a while tho. Do keep us updated with what you find and how much help you get from Easy Wiring.
I just don't see the justification for Painless or Francis to charge 3 X as much for their harnesses, it isn't like they are using mil spec components or gold plated wire or anything else that justifies the higher price, a harness is pretty basic, when all is said and done the major difference is in the profit margin.
Interesting problem...good thing you're a EE. I have an EZ wiring kit here in the box so I checked the backside of the fuse block to see how the input power is bussed. What I find is that there is no single bus like in a residential power distribution panel, however there are at least 5 bus bars connecting various "+" side fuses. I don't have the schematic here in front of me but from what I can see in the wiring of the fuse block there are many input voltage source lines coming into it. The first place that I would look is the junction between the "+" battery cable and the lines that feed the fuse block. Intermittent problems are a PITA, good luck with your troubleshooting!
One feature I like with the EZ wire kits is the ability to pop a circuit wire and connector out of the fuse block without damage and put it away for future use if you decide to add more accessories later. Technology is always changing who knows when the next "must have" device will hit the market, our you or your SO decide you want more creature comforts.
Direct replacement harnesses are aimed at the restoration purist, 6V positive ground for the 53-55, 12V negative ground for the 56, but they do not use a fuse block, Ford didn't use fuses in the mid fifty's trucks, just a couple self resetting circuit breakers protecting all the (minimal) circuitry. This makes it difficult to do any upgrading, even "modern" halogen sealed beam headlights, or alternator can overload the breakers, and forget running your smart phone or laptop off the cigarette lighter plug.
Thanks
Ralph
I haven't looked at one of their large size fuse blocks, but since they are OEM they probably work the same way. There is a small spring tab on the connector where it goes into the block that snaps into a notch. If you use a very small screwdriver or even a paper clip from the fuse side you can release the tab and the wire and connector can be pulled out (assuming you have taken the fuse out first. LOL!). Take care not to bend the tab and it can be pushed back into place, replace the fuse and run the wire to whatever you want to power. No coils of wires hanging under the dash.
I apologize for hijacking this thread...but my wiring problem is somewhat related to the original question.
I pulled the fuse block loose from the firewall again and inspected it. The only thing that I can see that might be a problem is the fact that the main power wire coming from the battery is crimped and not soldered at the connection at the bus bar. That being said, I still can't reproduce the problem at will. I've tried shaking, twisting, and contorting it in every way possible but I can't reproduce the failure.
Would any of you guys happen to have a wiring diagram for the EZ Wiring 21 circuit harness? If not, I can try to reach them after the holiday.
I want to start tracing out some of the circuits to see if I can find a problem.
Peace,
-DV
Peace,
-DV
#29
#30
I could not find a diagram of the fuse block in the manual but here are a few photos of mine. You are right, you should not need this diagram...IMO your problem lies outside the fuseblock. I would disconnect the battery and run a continuity check from the battery terminal to the fuse block input lead...somewhere between the two is a splice that is flakey. Move the wiring bundle as you watch the meter, look for a dip when the open occurs. As for the crimped connection, that is very common for any electrical connection where higher current is expected to be flowing...solder has a tendency to melt and so it is not employed under these conditions.
