2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
disconnecting power mirrors?
Old 09-01-2012, 07:28 PM
evilwunn's Avatar
evilwunn
evilwunn is offline
Like others on here I can't get my drivers side power mirror memory settings to work right. I don't really need them to move once they are set where I want them, so would disconnecting them so they stop moving around mess anything else up like the seat memory settings?
this is on my 2010 EB expedition.
Old 09-05-2012, 07:14 AM
evilwunn's Avatar
evilwunn
evilwunn is offline
anyone......anyone...
Old 09-20-2012, 08:36 PM
cstanley44's Avatar
cstanley44
cstanley44 is offline
Do you mean you dont want your mirrors to move at all?
Or you dont want the memory to move them when you unlock with the key fob?
If the first, there's likely a fuse, but there's probably some other feature on the same fuse too.. not ideal
if the latter, set your memory seats with the memory seat button only. This should eliminate any mirror movement as to set the mirrors you have to set the seat and within 5 seconds, hit the remote to unlock. (I accidentally set to 'lock' on the remote so when I realized and set it to 'unlock' it worked well)
Old 09-21-2012, 11:36 AM
evilwunn's Avatar
evilwunn
evilwunn is offline
Thank you I'll give that a try
Old 09-21-2012, 05:53 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
I was having a similar issue with the passenger side mirror not always going back to where it was set. I ended up bringing it in and had Ford replace the mirror motor and it's been fine since. Tech said the "motor pack" is a common issue.
If yours is still under warranty it's worth a shot.
Matt
Old 09-23-2012, 06:36 AM
evilwunn's Avatar
evilwunn
evilwunn is offline
Matt
Thanks Matt, it is still under warranty maybe I'll take a ride to see them this week and have them check it out.
AaronLane
07-28-2017 09:53 AM
Herbert
1997-2006 Expedition & Navigator
06-23-2010 08:19 PM
rconnjr
03-08-2009 08:01 AM
holeshot440
09-30-2008 09:30 AM
termite32
1999 to 2016 Super Duty
03-19-2008 11:10 PM
Quick Reply: disconnecting power mirrors?
