F150 gas tank size - Ford Truck Enthusiasts Forums
F150 gas tank size
Old 05-14-2003, 09:15 PM
kenny150 kenny150 is offline
kenny150 is starting off with a positive reputation.
F150 gas tank size
I have a 1992 F150 Standard Cab Shortbox 4x4 pickup with the 302. My gas gage does not work (seems like a common ford problem) however, my gas tank seems to be tiny. I figure its somewhere around 14 gallons. Does anyone know or can anyone direct me to where I could find this information? Thanks a bunch guys.
ken
ps. This is my first post on the forum and I am very excited to have found a source of information like this.
Old 05-14-2003, 09:29 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
F150 gas tank size
It's in the Haynes manual.
Old 05-14-2003, 09:55 PM
rebel_ford4x4's Avatar
rebel_ford4x4 rebel_ford4x4 is offline
rebel_ford4x4 is starting off with a positive reputation.
F150 gas tank size
drive til you run outta gas then when you fill up see how many gallons it takes
Old 05-15-2003, 12:42 AM
PMD66 PMD66 is offline
PMD66 is starting off with a positive reputation.
F150 gas tank size
My owner's manual says one tank is 19 gallons and the other is 17. If I fill up at the 1/8th mark, both tanks turn off the pump around 15 gallons.
Not too sure about running 'till empty, though. The sediment could be drawn into the pumps and filter...
Old 05-15-2003, 09:31 AM
steve83's Avatar
F150 gas tank size
The pumps ALWAYS pull from the bottom of the tank, so the sediment would get sucked up all the time. But there's a big filter on the bottom of the pump to stop that. Take a look.
Old 05-15-2003, 10:35 PM
jarrod316 jarrod316 is offline
jarrod316 is starting off with a positive reputation.
F150 gas tank size
Short box 4x4's only came with one tank. the rear tank. it is an 18 gallon tank. this info is in the owners manual. hope this helps
Old 05-16-2003, 11:52 AM
Blue96
Guest
Posts: n/a
F150 gas tank size
Gotta disagree 316
My shortbed F150 has a 15 gallon tank. no duals.
On a cold morning near empty i can squeeze about 16 into her.
1994 F150xl dual tank problem NativeDescent 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2014 05:23 PM
odd problem with front tank cmb2481 1987 - 1996 F150 & Larger F-Series Trucks 1 08-15-2013 12:45 AM
Rear fuel tank issue brucers Ford Inline Six, 200, 250, 4.9L / 300 3 08-26-2011 08:03 PM
Gas tank overflowing! RickUhrig 1987 - 1996 F150 & Larger F-Series Trucks 62 05-27-2005 10:58 PM
Gas gauge problem gcfisher75 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-11-2002 05:33 AM
Tags
1992, capacity, dual, f150, gas, rear, size, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
