Spark Plug Change 2009 F-150 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009 - 2014 F150
Sign In
Register Forgot Password?
Old 09-01-2012, 04:04 PM
Rongor Rongor is offline
Rongor is starting off with a positive reputation.
Thumbs up Spark Plug Change 2009 F-150
Good afternoon all,
This is my first post to this forum but I thought I would share my experience in changing spark plugs on my 2009 Ford F-150 XLT with 4.6 L V3 engine.
My truck has just over 135,000 kilometres (83885 miles) and I recently noticed it would make a jingling noise while accelerting. I began to use a higher octane fuel and the jingling stopped however these trucks are meant to run on 87 octane fuel which I'd rather use due to the price of premium fuel being so high.
Yesterday I took my truck into a Ford Dealership (Quick Lane) for a lube, oil and filter and inquired what service should be done at 130,000 km as I bought my truck used last year and didn't get a service manual. I also have no idea of the trucks service history prior to my owning it.
The Ford service person recommended that I get a tune up (which according to the service person was only changing spark plugs), a transmission service (drop the pan, change the filter and replace fluid) and a coolant flush.
Ford quoted me $325.96 plus tax to change the spark plugs (apparently Ford takes two hours for this). They also quoted me $141.00 plus tax for the coolant flush and $196.55 plus tax for the transmission service.
I'm the kind of person that would rather try to save some money by doing it myself. I began to research how to change the spark plugs on this vehicle and came up with lots about spark plugs breaking in the head as it was a two piece design. I also learned that this problem was corrrected after 2008 so the plug removal should not be that difficult.
I ventured to my local Ford dealership and purchased 8 MotorCraft Platinum Spark Plugs (Part # SP509 / HJFS-24-FP) which are priced at $15.12 each for a total of $136.68 with tax. I spoke to the parts persons and was told that if I went looking for a cheaper aftermarket plug that I would likely be back as the Motocraft plugs a specially designed for this vehicle. I was also told to set the plug gap to 0.41. He also suggested that I change the plugs after the engine was warmed up (but allowed to cool sufficiently so as not to burn myself).
Changing all 8 plugs took me about an hour and I had no isses at all removing the old plugs. The biggest issue I had was locating a 14mm spark plug socket (which I never did find at Canadian Tire). I ended up using a 14mm deep socket and a piece of rubber tubing to pull the plugs out of the head. (Apparently Candian Tire only have 5/8 and 11/16 spark plug sockets).
In changing the plugs, the only thing I had to remove beyond the plug wires was the air intake filter on the drivers side which was basically loosing two screws removing both ends and laying it on the top of the engine with everything still attached. I put a cloth into the exposed air intake valve (can't recall what it's actual name is).
After the plugs were changed and everything was put back together, I test drove the truck. It seemed to be a tad more responsive and the jingle that I had been noticing was not present. Hopefully this was my issue all along but it will take some more road testing to be sure however I'm encouraged by the early results.
Ford Cost to Do: $325.96 plus tax ($368.33)
My Cost to Do: $136.68 and 1 hour of my time
Savings of: $231.65
This was not a difficult job to do and would encourage anyone to consider doing it themselves.
I know this was a bit long winded and may seem like a novice task to many but it it's helpful to even one person then it was worth the time to type up.
Ron
Old 09-02-2012, 06:35 AM
tseekins's Avatar
tseekins tseekins is online now
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Ron,
Great first post and welcome to FTE!
If I purchased a used truck I may consider having the transmission fluid changed as well. But, if you know anything about it's history and can determine that it hasn't towed heavy then your transmission shouldn't require service, "not to exceed" 150K miles or the metric equivalent.
There should be an owners guide that came with the truck. This will breakdown all the maintenance intervals for you.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
Old 09-02-2012, 06:40 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
tim.burke.167
What Tim said! Welcome to the Forum
__________________
~ Tim ~
If you can't stand behind our Military, feel free to stand in front of them!
'10 F150 XLT 4X4 CC shortbed 5.4 *5 Star tuned* No Bailout Edition , 07 Road King Classic
"The world is a dangerous place to live; not because of the people who are evil, but because of the people who don't do anything about it." - Albert Einstein
Old 09-02-2012, 12:09 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Welcome to the forum. Nice write-up.
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
Old 09-02-2012, 03:33 PM
Thanks for the warm welcome. The truck has an after market electric trailer brake control under the dash so I'm pretty certain it was used to tow so I think I will get the transmission serviced just to be safe. I have to say as a first time Ford F-150 owner... I love it! Cheers.... Ron
Old 09-03-2012, 02:23 AM
EddyHruby EddyHruby is offline
EddyHruby is starting off with a positive reputation.
There should be an owners guide that came with the truck.Click the image to open in full size.
Old 09-03-2012, 03:03 PM
Yeah.. when I bought it the manual was missing but have just downloaded one off the internet so all is good. thanks
Old 09-03-2012, 04:59 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
It almost sounds like they were halving the time and cost to do a 5.4 with pre-2008/9 heads...Good job on doing it yourself...saved you some $$. Oh, and welcome!
Old 09-03-2012, 08:43 PM
Chadwilliam1 Chadwilliam1 is offline
Chadwilliam1 is starting off with a positive reputation.
those are some expensive plugs, did you change the wires too?
Old 09-04-2012, 02:14 PM
Thanks for the welcome...
I know the plugs were expensive but that's cheaper than what NAPA quoted me for their "comparitive" plug.. I think they were NGK??? Those were $24 and change each.
I'd be interested to hear what other plugs/prices work well in the 4.6L to see if the Ford parts person was feeding me a line?
Old 01-05-2013, 11:44 AM
rm09f150xlt rm09f150xlt is offline
rm09f150xlt is starting off with a positive reputation.
I need to change the plugs on my truck.... good to know its not that bad of a job! Good to know its nothing like the older F150 plugs. Thanks for the write up!
Old 07-20-2014, 07:49 PM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputation
Old thread, I know, but what torque specs did you use on the plugs?
__________________
A. Ortiz
2000 Excursion 5.4 4X2
Similar Threads
Spark Plug thread repair. With Photos tmehrkam Modular V10 (6.8l) 37 10-16-2014 07:26 PM
#8 5.4 Cylinder COP/Plug Change JWA 1968-2013 Full Size Vans 0 01-17-2014 07:42 AM
('07) 5.4l Ford Triton 3-Valve Stumbling Under Load *Solution* SS_Autowerks Expedition & Navigator 3 03-11-2013 04:04 AM
My Story: Transmission Problems or Spark Plug Problems KC Excursion 2004 - 2008 F150 4 10-06-2012 06:30 PM
5.4L Spark Plug Change Details....................... 1999XLT Expedition & Navigator 7 07-26-2002 08:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
