Leaking exhaust manifolds - Ford Truck Enthusiasts Forums
Old 09-01-2012, 03:52 PM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is gaining momentum as a positive member of FTE.TheTinian is gaining momentum as a positive member of FTE.
I recently bought this 01 F350 dually. Its had a noise since the day I bought it, but it never really effected anything so I let it go. Lately it has gotten worse. Boost and EGT is still ok, but MPGs has dropped and the noise has gotten louder. I was changing the oil today and found out where it was leaking. Almost the whole back side of the block is covered in soot. The old oil filter was black too. I did some research and seems its 50/50 to get the gaskets or get a new manifold. What kind of job am I in for? It looks like its going to be a pain in the ***, but I know if I go to a shop they will probably charge me alot more than I want to pay..
Old 09-01-2012, 06:10 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
Never done it but I am sure if you search the forum there will be info on it. I.know I.have seen people talk about it before.
Old 09-01-2012, 08:40 PM
Edkajo Edkajo is offline
Edkajo has a good reputation on FTE.Edkajo has a good reputation on FTE.
Not meant to hyjack but I was just ready to post about what appears to be an exhaust type leak somewhere on my 03 7.3. It runs and idles fine. I thought it might be a bad manifold or gasket but I can't seem to locate it at idle or see any signs while having it revved in neutral. Did your's sound fine at idle and only have a putting sound while excellerating under load, almost like a bad exhaust tube sound in a gasser? Is there anything else on a 7.3 that you know of that could cause this type of sound? Again, very sorry, I just didn't want to ask something similar in a new thread.
Old 09-01-2012, 08:47 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
If I recall there are no gaskets in your exhaust. So new manifolds would be required.
Good opportunity to also get some up pipes to preven future leaks.
Old 09-01-2012, 10:56 PM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
There is a Dorman part that has both the gaskets and manifold with up pipe bolts and nuts. Part numbers 674746 (left) and 674745 (right).
I did find the gasket for the exhaust.
VICTOR REINZ Part # MS16314 ($14.42/<acronym title="Page Ranking">pr</acronym>), FEL-PRO Part # MS93489 ($18.56/<acronym title="Page Ranking">pr</acronym>), DNJ ENGINE COMPONENTS Part # EG4200 (20.99/<acronym title="Page Ranking">pr</acronym>). All of these numbers are for a set of gaskets. I am still looking for the bolts.
EDIT: Found the bolts (called exhaust manifold studs on rockauto). So much for being accurate the first time.
All items found on rockauto.com.
Old 09-01-2012, 11:54 PM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
Old 09-02-2012, 12:01 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
that is one major leak. sure it aint where the up pipe bolts on to the manifold. In regards to the gasket, I have used one and would not do it again. The gasket crept and started to leak again. You can have your manifold matting surface machined flat which will give you the seal you need. But I would be surprised if that is the case with that much soot.
Old 09-02-2012, 12:20 AM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
x2 i have read where the gaskets dont hold to good, i would put new or machine it flat.
Old 09-04-2012, 05:47 PM
TheTinian's Avatar
Quote:
Mine sounds perfectly normal under 10lbs boost .... 10-11 lbs or more is when I can hear it...
Quote:
I thought about that, maybe Ill fix the uppipes first and see if its still leaking. And thanks everyone else for the replies, Im not looking forward to doings manifolds..
Old 09-04-2012, 08:30 PM
duck fan's Avatar
duck fan duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Don't buy new manifolds. Don't buy gaskets. Remove yours, take them to the local machine shop and have them machined flat and them reinstall them. Its not too terrible of a job. Jack up the front end of the truck. Put some jackstands under it. Remove the front wheels and then the fenderliners. Manifolds will be right in front of you. Its even easier than it sounds,
http://www.ford-trucks.com/forums/89...eak-fixed.html
Old 09-04-2012, 11:58 PM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
What DuckFan says. I had mine machined, then pulled the driver's side off again and installed a FelPro gasket, as I wasn't sure it was sealing well. Neither side has leaked again, and I'm not sure the gasket was necessary.
Mark
Big Florida Trucks TheTinian Offroad & 4x4 18 04-24-2011 12:16 AM
Here it is. TheTinian Offroad & 4x4 139 07-08-2010 07:54 AM
My complete Build Thread- 99 1 ton F150 TheTinian 1997 - 2003 F150 7 06-17-2010 10:17 PM
Some "poser" flex pics....... TheTinian Offroad & 4x4 28 05-26-2009 02:07 AM
Weekend Wheeling, Breaks, and new 44 Boggers. Lots of pics... TheTinian Offroad & 4x4 39 04-30-2009 10:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
