gear ratio?
I wouldn't go higher than 4:10s since your are only towing 10 times per year. Plus if you go with a lower gear ratio you will be able to slap 35s under that thing since you have a 6 inch lift and it will look ten times better and tow your trailer with out any problems. Hell I only have a leveling kit and I am running 35s on mine with 3:73s.
putzhall3
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-05-2005 05:28 AM
