Fuel injector flow rate? - Ford Truck Enthusiasts Forums
Old 05-14-2003, 08:53 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
I have 1992 E150 with a 351 and need to know what flow rate the stock injectors are..... Mine are red topped. I have no idea what they are all the literature online says 30 lb/hr, and mostly found in the '92 Super Coupe....... Is it possible this has been worked over?
Old 05-15-2003, 07:34 AM
StrangeRanger StrangeRanger is offline
StrangeRanger is starting off with a positive reputation.
Are they a deep red or a red-orange? I'm pretty sure the stock ones are 19# same as a 302, the 351 doesn't make that much more peak HP, just a ton more throughout the rest of theRPM range. 19# units normally have red-orange tops.
Old 05-15-2003, 08:32 AM
pfogle's Avatar
they appear to be a dark red from what I can see.
Old 05-15-2003, 03:19 PM
Yelrisheam Yelrisheam is offline
Yelrisheam is starting off with a positive reputation.
It's my understanding stock injectors were @ 19#, although if you cruise the net, you'll get dozens of different answers (e.g. fiveomotorsport.com lists the stock injector for that year as 21# which is a purplish color). My '93 does have the 19's in it, and any increase in injector gph will require a map sensor calibrated for that flow rate. Increasing the flow rate on a 351w with stock heads is pretty much useless, and normaly most folks don't up-grade injectors unless their going to increase the breathing capacity of the motor.
Yelrihseam.
Old 05-15-2003, 06:06 PM
pfogle's Avatar
The only history I know about this van is that a racing team used it to tow their stock car, and it was also the service vehicle while at the track.... It still has the grease stains in the carpet..... It gets really good gas mileage and performs better than most other vehicles I have driven, also lopes a little at idle.
Old 05-19-2003, 03:16 AM
brian_06328 brian_06328 is offline
brian_06328 is starting off with a positive reputation.
Have you taken a good look at the heads on the van? Are they iron or aluminum? I have seen a lot of guys at the track who have put some serious $$$ into their tow rig motors.
You might have come across one of the ones that are built well enough to need 30# injectors. If they built their race engines, they would probably know the right injectors to put with the tow motor.
Another consideration might be that the injectors are made by a different company that uses red for their 19# or 24# injectors (FYI- that last thought is just a wild stab on my part , I've heard that Accel's 19# injectors are bright yellow )
Brian
Old 05-20-2003, 09:57 AM
pfogle's Avatar
they appear to be iron, however the van runs like a raped ape, 0-60 in under 9 seconds, (around 8 last time I clocked it) empty. Also it tows like no tomorrow, it's pretty bad when a full size van towing about 8000 pounds up a mountain is pulling away from the mini-van behind it. (we had stopped to secure the straps on the trailer and we couldn't catch dad in my van.)
down sizing injectors? 1veryShort1 1997 - 2003 F150 1 06-06-2014 03:11 AM
42lb Bosch Ford Motorsport injector spec's hquick Fuel Injection, Carburetion & Fuel System 3 04-14-2008 06:28 PM
Fuel injector identification rhetor Ford Inline Six, 200, 250, 4.9L / 300 4 01-25-2006 03:17 PM
Fuel injectors - 4.0L rusty70f100 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 6 07-29-2005 03:51 PM
Stock CATALYTIC Converter flow rate? fordextreme Modular V8 (4.6L, 5.4L) 1 03-30-2002 06:34 PM
Tags
1992, 40, 460, 54l, bronco, color, diesel, f150, flow, ford, fuel, injector, injectors, lbs, rate, rates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
