ROSEWOOD STAGE 1.5 OR 2? - Ford Truck Enthusiasts Forums
Old 09-01-2012, 11:45 AM
smash fascism's Avatar
smash fascism smash fascism is offline
smash fascism is starting off with a positive reputation.
I have already purchased my s366 turbo and t500 oil pump. I want a reliable truck, do you think the stage II's would be ok?
Old 09-01-2012, 11:57 AM
Ford4Life7.3's Avatar
Ford4Life7.3 Ford4Life7.3 is offline
Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.
Quote:
People typically go with stage 1's or 1.5's with the s366 it seems. I guess if you wanted to get a little extra power you could have the stage 2's tunes down to right where its best for you. Id say go with the 1.5's
Old 09-01-2012, 11:58 AM
Then again i believe there are guys eunning stage 2'a with the d66 which is more or less the same.
Old 09-01-2012, 12:38 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Go with stageII's 180/80
Keep in mind to run the s366 you have to go with e-fuel if you using the irate mounting kit.
You'll also need a IC or get creative with a intake spyder
That set up with the right tuning will put you around 425hp
Old 09-01-2012, 12:57 PM
why do I have to run E fuel?
Old 09-01-2012, 04:23 PM
fordpride's Avatar
Cause the irate kit uses the hole for the stock fuel pump as the oil return for the turbo
Old 09-01-2012, 10:29 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I'll probably go with the stage 2's like you have Mike but is it an option for the springs, head studs and push rods or a must have? If its a must have then I might just go with stage 1.5's, IDK!
Old 09-01-2012, 10:44 PM
fordpride's Avatar
It's only a must have if you plan on running hard high RPM'S like racing and WOT runs. Just using it to tow I think you'd be fine. I just don't see you towing at 40psi of boost
Old 09-01-2012, 10:48 PM
fordpride's Avatar
You could always do a set of 238/100 hybrids the you can have them tuned for any injector from stock or stageIII or anything in between
Old 09-01-2012, 11:56 PM
hahahaha, no I can't see towing at 40psi of boost, that's for sure. Mine will melt down now at a continuous 20psi towing.
I'll be honest, I don't know enough about the different size injectors.
Old 09-02-2012, 12:08 AM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
I'd go size two and have them detuned. You really can't go bigger on flow than what you have. But you can sure go lower.
Old 09-02-2012, 08:08 AM
Yeah I was considering hybrids, but seems though im already changing the HPOP I shouldnt have to worry about running out of oil should I? Is there any other plus to having hybrids besides the fact they use less oil?
Stage 1 vs Stock Injectors damons 1999 - 2003 7.3L Power Stroke Diesel 97 09-16-2011 10:19 PM
Installed injectors and now runs rough! cjfarm11 1999 - 2003 7.3L Power Stroke Diesel 9 02-20-2011 09:01 AM
Stage I, II, or III injectors? Which to chose? cutlass 1999 - 2003 7.3L Power Stroke Diesel 11 01-06-2011 07:47 PM
stage 1 and stage 2 injector differences? Boss300 1999 - 2003 7.3L Power Stroke Diesel 16 12-10-2008 04:18 PM
Stage 1, 2, 3 ??? fnx4wheeler Appearance & Dress-Up 1 10-08-2007 06:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
