Dana 44HD TTB or Dana 50 TTB - Ford Truck Enthusiasts Forums
Old 08-31-2012, 09:24 PM
nonrev321 nonrev321 is offline
nonrev321 is starting off with a positive reputation.
Hello,
I'm going to be doing a rehab on a 1985 F-250HD 4x4 I bought recently. The engine is just about done and next I want to rebuild the front axle. From what I have been reading I either have a Dana 44HD TTB or a Dana 50 TTB. How can I tell which one I have?
Thanks in advance for any info
Rgds
nonrev
Old 08-31-2012, 10:46 PM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
Going off of memory here, the 250's all had the Dana 44HD, while the 350's had the Dana 50. Someone can correct me if I'm wrong...
A Dana 44 in an F250 should have hubs just smaller than the mounting flange. If it's the same size as the flange, then it'll be a Dana 50. You should also be able to identify it with the tag on the front if it's still there.
Old 09-01-2012, 03:42 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
All diesel 250s and i believe the high gvwr gassers got the dana 50. The third member has a cast in number on the bottom that will tell you which axle you have by either saying 44 or 50.
Old 09-01-2012, 07:13 AM
blucollar4xford's Avatar
blucollar4xford blucollar4xford is offline
blucollar4xford is starting off with a positive reputation.
I've seen plenty of diesels with the 44, and two friends of mine have smallblock F250's with the 50. One is even a light duty truck with the semi float sterling. Check here for more info;
http://www.ford-trucks.com/forums/10...tb-thread.html
D44 hubs will measure 3", while the D50 hubs are 4".
Old 09-01-2012, 09:21 AM
Thanks everyone, its appreciated
Old 09-01-2012, 02:43 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
The D44 hubs taper, while the D50 hubs are the same diameter right out to the wheel locks.
Old 09-01-2012, 08:09 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Once again, all f250's came with a dana 44hd ttb, any engine.
Extended cab f250's and possibly some special order regular cab 250's came with a dana 50ttb
All f350's from 1980 thru 1985.5 came with a dana 50 ttb and after that, the f350's had the dana 60.
dana 44/dana 50 compatibility justcruzin125 1987 - 1996 F150 & Larger F-Series Trucks 2 11-09-2016 10:48 AM
dana 44 ttb hd parts on a solid axle d44 david.77 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-27-2013 06:43 PM
If you were rebuilding a 460 what would you do? nonrev321 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 24 01-19-2013 09:39 AM
TrueTrac Dana 44(HD) TTB and Springs nonrev321 Clutch, Transmission, Differential, Axle & Transfer Case 0 09-30-2012 08:07 AM
Dana 44HD differences from Dana 44LD nonrev321 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-08-2012 01:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
