Cheap lift kits on Ebay...
Old 08-31-2012, 11:05 AM
king-david's Avatar
king-david
king-david is offline
My research (read searching through the boards here ) says that F250 kits will work for the Ex... I found these cheap kits on ebay.
99-04 FORD F250 4x4 2.8" Front Leveling lift kit F-250 | eBay
I'm only looking for a minor lift. My wife doesnt want to 'climb' into anything. This is just a 2.8" lift and for less than 100$ i feel like I'm missing something... Could it really be that cheap to lift these trucks?
Old 08-31-2012, 11:44 AM
Andrew Echeverri's Avatar
Andrew Echeverri
Andrew Echeverri is offline
thats just a leveling kit to bring the front up
Old 08-31-2012, 11:45 AM
king-david's Avatar
king-david
I read that.. but it says 2.8 lift level. What exactly does it do?
Old 08-31-2012, 12:08 PM
EXv10's Avatar
EXv10
EXv10 is offline
It's actually expensive for what it is and they are the same as front blocks which might be illegal. They only lift the truck and have no effect on bottoming out. There are shackles in there which I plan to get soon that start at $40 and many lengths and will help bottoming.
Old 08-31-2012, 12:14 PM
king-david's Avatar
king-david
Ok cool. I didnt plan on lifting any time soon... but I saw them for so cheap I thought it might be cool to buy them and sit on them till I'm ready. Let me know when you do yours.
ToMang07's Avatar
ToMang07
ToMang07 is online now
Custom Diesel has a similar kit that ships for $100....and is made in the U.S.A. I got about 2" of lift from it...very happy with the kit.
Another thing to think about, is you may need a track-bar drop bracket or an adjustable track bar, as it will likely un-align the axle.
The biggest difference between blocks and a mini-spring pack is they have a center pin that goes through them and the actual leaf springs so they can't "pop out" like a block can on the front. (Why most states make a block in the front illegal.)
Old 08-31-2012, 12:15 PM
ToMang07's Avatar
ToMang07
Old 08-31-2012, 12:17 PM
king-david's Avatar
king-david
I'll have to look into Custom Deisel!
Old 08-31-2012, 12:26 PM
blowery's Avatar
blowery
blowery is offline
Blocks on the front are a BAD IDEA! go with lift shackles, or drop hangers or add a leafs.
EXv10's Avatar
EXv10
EXv10 is offline
Still the same as front blocks with cast pin and hole. Pretty much useless and no effect on bottoming. I'm sure it was a ploy to get around using blocks. Overpriced and unsafe as blocks.
Old 08-31-2012, 12:35 PM
king-david's Avatar
king-david
These look like mini leafs added to the spring in the front. I think I'll check out the kit tomango was talking about either way, or Exv10's method. Thanks.
Old 08-31-2012, 12:38 PM
blowery's Avatar
blowery
blowery is offline
Yep there are a lot better ways to lift.
Old 08-31-2012, 01:12 PM
EXv10's Avatar
EXv10
EXv10 is offline
They are very short and same as blocks. Expensive garbage. You like bottoming out? No need to wait for me to act, I already know what the outcome will be.............go shackles
Old 08-31-2012, 01:21 PM
ToMang07's Avatar
ToMang07
I would LOVE to hear your reasoning behind this bold statement.
How much are (4) U-Bolts alone?
$100 shipped is a pretty damn good deal in my book....especially since the ride doesn't get harshened up from add-a leafs.....and a whole lot cheaper than new shackle/hanger kits.
Old 08-31-2012, 01:39 PM
EXv10's Avatar
EXv10
EXv10 is offline
$100 shipped is a pretty damn good deal (not really) in my book....especially since the ride doesn't get harshened up from add-a leafs.....and a whole lot cheaper than new shackle/hanger kits.
If you read my posts you will see that the shackes start at $40 (and they are 3/8" thick.) What U-bolts? Plus they don't affect the ride and you get the added bonus of less bottoming.......what's to lose? Just admit you missed the boat.
Quick Reply: Cheap lift kits on Ebay...
