Compatible coolant? - Ford Truck Enthusiasts Forums
Compatible coolant?
Old 08-31-2012, 10:24 AM
davbeisner's Avatar
davbeisner davbeisner is offline
davbeisner is starting off with a positive reputation.
Compatible coolant?
I'm fixing to do a coolant flush and refill on my '03 F-250 6.0 liter engine... The guy at the local parts store (CarQuest) gave me Zerex G-05 Phosphate Free Antifreeze Coolant... according to the back of the bottle, it's approved for model year '02 and newer Ford trucks and also approved for all heavy diesel engines (i.e., CAT, Cummins, Detroit, John Deere, Mack, etc.) Is this the right coolant for my engine? Do I need to mix it with water before I put it in, or can I dump a bottle, fill the bottle with water, dump that, move on to the next bottle, fill it with water and dump that, move on, etc? And I assume distilled water would be my best bet, right? The well water where I am is extremely hard with minerals and I definitely don't want to use it.
He also recommended I do a flush using Prestone's Super Radiator Flush and sold me one bottle of it... after reading the back of the bottle, I'm discovering I'll need two bottles to do it right. What do y'all think about doing a flush with something like that? Necessary? Optional? Not a good idea?
I'm about to jump over to the tech folder and look up the instructions for doing the flush... I've never done one before. Any tips and tricks beyond what's there are welcome!
Thanks!
Old 08-31-2012, 10:39 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Zerex GO-5 is the same stuff as the Ford Gold.
No matter which you decide to use, many have switched to an Cat EC-1 rated ELC, you need to make sure it is "concentrated". Not 50/50.
Old 08-31-2012, 11:05 AM
davbeisner's Avatar
The new Cat EC1 rated ELC has to be concentrated, or the Ford Gold has to be concentrated? And what's the reason for switching to the other type?
Old 08-31-2012, 11:47 AM
You need to use concentrated after you flush. Doesn't matter which fluid.
See the thread on ELC below.
I need help: coolant system woes Jesser02EX 1999 - 2003 7.3L Power Stroke Diesel 26 07-06-2014 03:33 PM
Coolant help TinMan289 6.0L Power Stroke Diesel 3 05-30-2014 02:41 PM
Backflushing StrokinWarmblood 6.0L Power Stroke Diesel 5 12-12-2011 02:05 PM
Did I get screwed? Piolet 6.0L Power Stroke Diesel 15 06-22-2010 11:30 PM
03 coolant change flush questions dan_s_johnson 1997-2006 Expedition & Navigator 1 11-23-2009 09:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
