You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I sign off the ship next Wednesday and get home Friday.
I'll get and have good look at that exhaust down pipe soon after I get home and decide what to do.
Got a few goodies from Clay waitin', mainly maintenance items and spares to carry when running outback.
But the main thing I'm after is Kelly Safari TSR 'E' tyre info:
I've put a tread on the tire forum and the 99-03 asking about them but no replies.
This is what I asked:
G'day Fellas,
It has been asked some time ago; but I would like to see some more reviews on the Kelly Safari TSR. They've been around long enough now to have enough fellas put enough miles on them on their trucks. Especially like to know how they've behaved with the rear wheel torque produced by the heavy Diesel Trucks in particular the 7.3Ltr Trucks. Towing with these tyres on these trucks? etc.
I'm considering fitting LT285/75R16/E 126P Maximum Load Bearing Capacity (for a single tire) 3750lb @80psi. I know they are Load Range 'E' which is equivilant to the old '10 ply Rating', however I'm finding it hard to confirm the 'side wall ply'. I would hope it is '3 ply Side Wall'.
Cheers, Reg
Soooo, what I'm asking here is have any of you fellas out here in Aussie looked at these tyres. Their specs tick all the boxes and although I've not actually seen one, photos/promos of them look good.
I do believe they are '3 Ply' wall.
Cheers,
Reg
__________________ Aussie spec 2005 (US 2003) F-250 SD 4x4 7.3Ltr Powerstroke: PHP FU2 6 Pos’n Chip,6 x ISSPRO Guages, AIS Intake, Zoodad, Hutch'd n’ Harpoon'd. Cowl Hood, AIH Delete, CCV, RiffRaff FRx,HPx,OCR, JWVB. ARB Air Lockers Front & Rear,V10 Tranny cooler + Stock Tranny cooler, ARB Bull Bar. Long Range Fuel Tank,VMS in Dash GPS Nav.OME Suspension & Dual Tower Shocks, MOOG Ball Joints. GVWR (GVM) Upgrade to 5,000Kg (F350+).
Nope, never looked into these tyres. I have always run Mickey Thompson,s. I am currently running Dick Cepek FC2 315 x 75 x16. They are good all round and quiet.
G'day Wallsy,
I did look at MT tyres but they have nothing bigger in 16" than 265s that meet the Truck Specs. My door sticker for tyres state 265 75R 16" with minimum Load Range 'E' and Speed/Load Index rating 123R.
Other than the 265s there is nothing in the MT range that meets the minimum spec on the truck.
When I was looking to buy my first set of tyres, the local MT dealer would not sell me 285 MT tyres because they are only 'D' load range and only 122R, both below the minimum spec required.
They say you can go bigger in the actual tyre size but they must still have the same minimum construction and duty specs to be "truely" legal.
That is they have to be Load Range 'E' (old 10ply rating) and not Load Range 'D' (the old 8ply rating) and the Speed Load Index no less than (in my case) 123R.
I had much the same issue with Toyo and even rang the head office in Sydney about it. 265s no problem. 285s only in MT as the AT were only 'D' rated and 121 (I think). I didn't want Muddies so had to go with the 305 70R 16" 'E' (10ply).
I've researched the tyre thing to death and this Load Range thing seems to be were the most disagreement is. The opinions are very Polarised. There are those who say never ever put 'D' tyres on these heavy load, heavy torque trucks especially if you tow a lot and traverse a lot of gravel rough road (both of which I do). Others say "D" tyres are fine as long as they are bigger than the OEM tyres originally fitted .
Then again Opinions are like arm pits, everybody has them, problem is some stink .
So in order to to not end up in any camp, I intend using only 'E' and minimum 123R as specified on my truck by the manufacturer.
Dealers with BFG said they have dramas balancing them and keeping them balanced and much the same with Goodies. My local bloke won't sell Coopers etc; and on it goes .
So with the Kellys ticking all the boxes including price and easy to get over here, I was hoping to get plenty of feed back on them. After all Kelly are an American iconic tyre maker even though they've been owned by Goodyear since 1936.
Cheers,
Reg .
Reg, ask Clay direct (email) Im sure he could ask around for ya
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else - join the Australian Chapter here-Join Chapter
Just aquired 5 35" maxxis bighorns of my mate 3 near new ,2 80%
$500 the lot
__________________
Bryan.
2005 FORD F250 7.3L, Maxxis BigHorns 35's,16x10 alloy rims,5"Procomp/Icon Vehicle Dynamics lift,AIH Delete,CCV,FRX,HPX, OCR,JW valve body,mag-hytec rear diff cover,wicked wheel,Garrett turbo outlet,F6 chip,Custom 4" to 5" exhaust,All from clay @ RiffRaff,BD big trans sump,Carpc got the ****,got a IPAD in the dash now
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
