Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 08-31-2012, 07:55 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Aftermarket extended range fuel tank
See here:
:: The Long Ranger :: Ford F250
I've been doing some research and got the co to send me the fitting instructions for the F250 tank (model tr57) which the PO had put in my truck.
The tank is made as 2 tanks with linking hoses. The rear section is the larger with the top section of the tank extending over the drive shaft. The linked tanks hold 270Ltrs of fuel.
I looks like I should be able to just drop the front section to get to the stock fuel pick-up, which is reuse, in order to do the hutch mod. While I'm doing that I'm going to fit one of their fuel transfer pumps with a water seperator/fine filter after the pump and a coarse in-line filter before the transfer pump. The other trick is to loose the stock fuel-line push fittings between the fuel pick-up and stock fuel pump as they allow air to be sucked in, and replace each of them with two 180 degree off-set hose clamps.
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
