F150 Transmission sensor failure? - Ford Truck Enthusiasts Forums
Old 08-30-2012, 07:10 PM
boeckmannc boeckmannc is offline
boeckmannc is starting off with a positive reputation.
My 1994 F150 started out losing power throughout the gears and would not downshift when i hit the gas. gradually it got to the point to where it would not barely drive down the road, like it was stuck in overdrive or something. Latest condition is that the overdrive off light will start blinking constantly when im driving then will send the truck to neutral. I then hit the overdrive off button after turning the truck off to turn it off and the truck goes down the road, just no quick acceleration and no overdrive. Now its to the point where as soon as i start it the overdrive off light is blinking and the truck will barely move. When it does decide to move it hops into gear frequently killing the truck when this happens. Any ideas or has anyone experienced this type of issue?
Old 08-30-2012, 07:26 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like bad wiring at the transmission.
Take the solenoid shift pack plug out that is on the passenger side of the transmission hopefully behind a a heat shield. Take the back of the plug loose and see if you have bad wiring at the plug.
If the wire are OK there then unplug the TR sensor on the other side and check is wires.
Overdrive Light BLINKING (F250 SuperDuty) campbell99 1999 to 2016 Super Duty 73 01-11-2017 06:52 PM
Blinking Overdrive Light in '99 Expedition BriR 1997-2006 Expedition & Navigator 13 05-29-2016 10:10 PM
overdrive issue firstcerberrus 1999 to 2016 Super Duty 3 08-23-2011 07:19 PM
Overdrive problem 2424dj 1997 - 2003 F150 4 01-12-2007 06:13 AM
overdrive light jc2 Clutch, Transmission, Differential, Axle & Transfer Case 2 12-28-2006 07:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
