worn timing belt
The symptoms of a worn timing belt are that the engine doesn't run any more. In most failures that I've seen, the belt ends up loosing a few teeth, and the valve and sometimes the ignition timing get too far off to run. The tensioner will keep the crank, distributor if equipped, and cam in good time as it will take up any slack on the 'undriven' or unloaded travel of the belt. One portion is in tension pulling dist & cam, the other side is along for the ride. Most times the crankshaft will eat a few teeth, and that's that. It won't hurt the valves, and generally happens when one goes to restart, and it just won't.
Some belts had rounded teeth from the factory and some had square cornered teeth. Vintage dependent and I have no clue why.
tom
tom
4x4man514
1983 - 2012 Ranger & B-Series
12-15-2018 09:02 AM
