96 cluster tach swap, auto manual OK?
96 f150 m5od straight 6 non tach.
looking to buy a 96 f150 AUTO tach.
I want the cluster for the tach, but fear since its an auto cluster it wont be a direct swap. I dont want to take anything apart. just want to chuck the non tach cluster out and plug the new one in. thanks in advance guys!
-cluster im buying is here
B6 92 93 94 95 96 FORD F150 F250 F350 SPEEDOMETER CLUSTER GAS W/TACH MPH | eBay
2X on that. As long as its a 96 cluster going into a 96 truck, its all plug and play. The engine wire harness tells the tach which engine it has(6 or 8) as long as its not a diesel tach! That opens up a new can of wiring.
I recall a 97 f250/f350HD will swap directly with 96. Other years(92 to 95) will require pin swapping of the harness to the 96 cluster. There is a thread that tells all about the various years and how to use them.
I even swapped a tach cluster from a F-series into my 95 E-series van(bus conversion) to get the tach. That did require pin swapping and adding a tach wire to the coil. So anything is possable.
Walwal44
04-23-2014 09:37 PM
droppedf100
02-23-2009 10:19 PM
snakecharmed
11-04-2000 01:02 AM
