2wd transmission pan on 4x4 transmission
Old 08-29-2012, 01:40 PM
minnesotafisherman's Avatar
minnesotafisherman
minnesotafisherman is offline
Hey guys,
bought a 2wd transmission pan without realizing it for my 4x4 AOD transmission.
Bought the aftermarket for the drain plug.. and I know it's a 0.5 quart less fluid capacity, but would it be ok if I put this pan on my 4x4 transmission with a 2wd filter also?
Otherwise I'm just going to order a deeper capacity pan with drain plug and keep the 4x4 trans filter.
Thanks
Old 08-29-2012, 02:38 PM
subford's Avatar
subford
subford is offline
It will work OK if you just use the truck like a 2 wheel drive truck and not do any off road 4X4 type stuff.
The deeper pan was for when the truck tips or rocks. Ford has a ground clearance spec and that is why they had to put shallower pans on the 2 wheel drive trucks. Later on, 1999 and newer tucks even the 2 wheel drive trucks had the deeper pans as they now had the ground clearance.
Some larger 2 wheel drive RV had the deeper pan in the early 90's as they had the ground clearance.
Old 08-29-2012, 02:48 PM
minnesotafisherman
Thanks Bill,
I do plan on using the 4x4, mainly for winter. But however I do plan on using the 4x4 for off-roading occasionally. I would probably feel safer using the proper 4x4 pan then.
Old 08-29-2012, 04:11 PM
Puddy's Avatar
Puddy
Puddy is offline
More quarts, the better.
Old 08-29-2012, 05:03 PM
minnesotafisherman
Yep, just ordered a deep capacity AOD pan, holds 3 extra quarts of fluid.
Now just have to find that shift lever I need... going to some tranny shops out of town on Friday for that..
Old 08-29-2012, 06:19 PM
subford's Avatar
subford
subford is offline
I hope it was a E4OD deep pan and not a AOD pan.
Make sure you get a matching gasket for it.
If the pan has a newer flat mounting surface you can use a reusable rubber coated steel gasket.
If the it is a older type pan with raised rings around the holes then you have to use a cork gasket or it will leak (pore) ATF out.
Old 08-29-2012, 08:33 PM
minnesotafisherman
Thanks Bill,
Why would I need an E4OD pan? I got a deep AOD pan, this one:
The transmission in my '92 has been replaced with a 4x4 AOD out of a 1990 F150, as part of my 4x4 conversion.
I just bought a Fel-Pro gasket, it's black, I don't think it's a steel gasket?
Should I be getting a re-usable, like this one? The pan says it comes with a gasket, I would sure hope it's a re-usable, for the price I paid for the pan.
Moroso Transmission Pan Gasket Rubber with Steel Core Ford 4R70W AOD AODE Ea 084663931062 | eBay
Old 08-29-2012, 08:38 PM
subford's Avatar
subford
subford is offline
I am sorry I thought I read you had a E4OD in your first post and all the information I post above was for the E4OD.
I was also thinking that a 1992 4X4 with a 5.0L would have a E4OD.
So sorry.
I have a good memory but it just does not last very long.
Old 08-29-2012, 08:43 PM
minnesotafisherman
Oh no problem Bill! Stuff happens.
Btw think you could answer my question above your post? Thanks!
Old 08-29-2012, 08:49 PM
subford's Avatar
subford
subford is offline
Not sure why you would need it.
You have a drain plug and the new filter will last over 100,000 miles so you will not be changing the filter again.
Old 08-29-2012, 08:52 PM
minnesotafisherman
Yeah, true. If I ever change the fluid again I can just pull the plug, so much easier then removing and re-sealing the pan.
Can't wait until I get this new pan, my tranny pan leaks about a 0.5 quart/day right now. Has a bucket sitting under it whenever it's parked.
big ole ford
02-13-2019 06:59 AM
CamoF-250
08-31-2018 04:23 PM
SoCalAngler
04-24-2014 08:33 PM
boonie
03-19-2007 11:38 PM
factory594x4
11-14-2006 03:09 PM
Quick Reply: 2wd transmission pan on 4x4 transmission
