2011 Upfitter Switches - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-29-2012, 11:21 AM
corey.melancon corey.melancon is offline
corey.melancon is starting off with a positive reputation.
While waiting out Hurricane Isaac I deciede to install a set of PIAA 520 lights...
After reading several threads about using the upfitter switches I have a couple of questions:
  1. If I understand the previous threads on the subject, attach the appropriate #1 upfitter wire (under the dash & next to the Emergency Brake) to a pass through wire into the engine bay. Once this is done, this wire passed through back into the engine bay becomes the power on switch for the lights?
  2. How do I wire into the fuse box/relays under the hood to get the 30 amp feed?
Old 08-29-2012, 11:48 AM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
The #1 upfitter puts out a fused 25A (**). All you need to do is to wire that to your lamps, and ground the other leg.
If you need more than 25A (**), then you need to tap power from somewhere else and use a relay. For anything over 25A, my preference would be to wire directly to the battery.
But be careful with those pass-through wires, because they are not equal in size to the upfitter output wires. For 25A, pass your own #10 wire through the firewall.
I don't think you need more than 25A, but if you do, Google the proper wire size for the current needed.
I don't think you need this either, but if you ever do need to tap the fuse block, these work:
(**) Edit: I said 30A, but for a 2011 switch #1 and #2 are actually only 25A.
Old 08-29-2012, 02:06 PM
I am completely ignorant when it comes to electrical wiring..
Simply put:
  1. Run a #10 wire through the fire wall (into the engine bay) that is attached to the #1 upfitter switch wire.
  2. Run that #10 to the hot side of the light.
  3. Ground the light.
and then it should work???
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 08-29-2012, 02:10 PM
bpounds's Avatar
2 bit Californian
Yes, correct. Your only concern is that the lights combined don't draw more than 25A, but if they do, the worst that will happen is the upfitter fuse will blow.
On edit: I checked your owners manual, and switch #1 and #2 are only 25A for a 2011. Earlier years they had a 30A rating.
Old 09-02-2012, 08:04 PM
Works great, thanks for the help!!!
EGR delete Kit Installation TIPS phantomphixer 6.0L Power Stroke Diesel 16 04-04-2015 01:21 PM
My Key FOB is dead even after battery change Barbender 1999 - 2003 7.3L Power Stroke Diesel 22 02-08-2008 11:04 PM
Heater Core - Repeated Failure arkansas_bob Cooling, Heating, Ventilation & A/C 1 08-30-2005 01:22 AM
Ready for a 2005 F350 doublec4 Car/truck Buying Advice 12 09-24-2004 06:57 PM
Bad Fuel Tank selector valve Rick McC Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 05-06-2004 04:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
