Carb problem ?
Carb problem ?
I have a 66 econoline 170ci with a 1100 carb I just rebuilt as the truck was in storage for well over a year. The truck starts fine and idles fine but when I press on the accelerator, it wants to die out. If I keep the choke a little closed and keep the idle up the problem goes away.
I replaced all the vacuum lines and vacuum advance. No change. I also noticed that the clear fuel filter I put on it only has a little fuel in it when running. (Not sure if that is normal)
Any help would be appreciated.
Big Daddy T
13
09-30-2009 08:30 PM
59INA40
05-12-2009 09:34 PM
