Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-29-2012, 08:41 AM
chads chads is offline
Garage is empty, add now
chads is starting off with a positive reputation.
Carb problem ?
I have a 66 econoline 170ci with a 1100 carb I just rebuilt as the truck was in storage for well over a year. The truck starts fine and idles fine but when I press on the accelerator, it wants to die out. If I keep the choke a little closed and keep the idle up the problem goes away.
I replaced all the vacuum lines and vacuum advance. No change. I also noticed that the clear fuel filter I put on it only has a little fuel in it when running. (Not sure if that is normal)
Any help would be appreciated.
  #2 (permalink)
Old 09-11-2012, 01:21 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh is gaining momentum as a positive member of FTE.kenjh is gaining momentum as a positive member of FTE.
have you checked that the accelerator pump is squirting when the throttle is moved ??if the check ball isn't working ..no juice to cover the bog ,,and the choke will give it the rick mix to cover that..and yes some filters never seem to fill but work just fine ..
  #3 (permalink)
Old 11-03-2012, 07:35 PM
l8ntpianist22's Avatar
l8ntpianist22 l8ntpianist22 is offline
l8ntpianist22 is starting off with a positive reputation.
im new here,but ken is right on the money
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
