Trailer Brake controller Removal ?
Hey all,,Have recently been getting a "TBC Fault" message and the Beep, as the message goes on and off(annoying) looked around think its the Controler itself,,If I move the slider ****, and Jiggle it,,the message Blinks on and off as I move the Slider,,,Looking for the method of removing it from the Cubby Hole,,,Gave it a tug,,,and wiggle,,did not move,,must have a Clip or Tab to release it,,any help would be Great !!
Thanks,,Mark
Thanks,,Mark
It just snaps in. No fasteners to remove. I pulled the small glove box down, and then reach in and up to grab the module. Wiggle it around and it will pop out.
I had mine out to install upfitters, so the pics from that job might help you figure it out. See this link.
Installing Upfitter Switches - Ford 2005-2007 Superduty
charto911,
Have you disassembled the 7 way trailer connector at the hitch yet? I don't have the factory controller - I have a Tekonsha - hooked up to leave after camping and no trailer brakes. My problem was the wiring connector that plugged in to the back of the 7 pin connector at the trailer hitch. I have a pull behind 28' TT. Some cleaning with electrical cleaner and a good solid plug in cured my problem. My F-250 is an 06 also. Four torx screws and an unplug from the wiring harness on the back side and it comes off and apart for easy cleaning.
Brute440
1999 to 2016 Super Duty
01-22-2015 09:17 PM
