Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 08-28-2012, 06:28 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Some Coolant info for ya powerstroke
I have known for a while that the coolant Im running is not the best for my truck and I wasnt to concerned due to the fact I was changing my motor. You know - I will fix it then - lol. Well that has been over 12 mth and Im yet to put the motor in. So Im at that stage now and thought I would look it up so I can start fresh with this engine. This is a interseting read with some good instructions and is the way mine is set up. As for some Technical info (for Simon) read post #4
http://www.ford-trucks.com/forums/96...ml#post8935201
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #2 (permalink)
Old 08-29-2012, 04:14 AM
SSSimon SSSimon is online now
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Nice work! No tap water!
Does Nulon have a diesel specific coolant that measures up?
The Cummins truck maintanance place in the next town sells a diesel specific Extended Life Coolant (incidently which is blue) by the 20L drum called TEC PGXL Coolant
See: Extended Service Coolants
and:
http://dp-content.cummins.com/CP/cp_..._main_tips.pdf
I haven't changed over yet because you have to do the full flush as described in Brian's link because the joe-average coolant may not be compatible with the diesel specific stuff.
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #3 (permalink)
Old 08-29-2012, 05:08 AM
yep
Red Long Life Concentrated Coolant- Nulon Australia
__________________
Brian
  #4 (permalink)
Old 08-29-2012, 07:07 AM
2005 Ford F-250
Looks good - available by the 20L drum, designed for maximum protection against cavitation in wet cylinder liners in diesel engines. That's the stuff.
Now I also have another job to add to the list!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
