Rear tank filling front tank?
The other day i had my truck set on the rear tank and when i pulled in my driveway i heard something leaking on the ground.I then noticed that fuel was pouring out the filler cap. If i set the truck on the front tank everything is fine. Any ideas on what could cause this?
Ok man I get to enjoy the magic fuel fairy too. On mine its the rear pumps check valve that is supposed to prevent extra fuel returned from the fuel injection system from entering the rear tank that has failed. It sounds like on yours its the front tank. Here is a link to the info. https://www.ford-trucks.com/forums/2...driving-4.html There is also a nice diagram in the thread I made the other day about the same problem, before I figured out how to make the search box find the info I wanted.
[QUOTE=wrightme43;12214079]Ok man I get to enjoy the magic fuel fairy too. On mine its the rear pumps check valve that is supposed to prevent extra fuel returned from the fuel injection system from entering the rear tank that has failed. It sounds like on yours its the front tank. Here is a link to the info. https://www.ford-trucks.com/forums/2...driving-4.html There is also a nice diagram in the thread I made the other day about the same problem, before I figured out how to make the search box find the info I wanted.[/QUOTE
I read that wrong had a bad day..
jerrywc
06-23-2012 01:23 PM
TJS96F-150
12-10-2007 03:02 PM
kc8uvu
07-17-2007 04:28 PM
