Power Mirror Switch - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Power Mirror Switch
Old 08-28-2012, 11:22 AM
92aeroXLT 92aeroXLT is offline
92aeroXLT is starting off with a positive reputation.
Power Mirror Switch
Hey all.. my 88 power mirror switch is bad (per the ford dealer). My mirrors only go in 2 directions... my question is this.. can I get any power mirror switch from the same era (explorer, econoline, mustang)? Is it only the shroud that is different? Thanks for your input!
Old 08-28-2012, 03:29 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
I would take the old switch to the local scrapyards and look for a van like yours and get a matching switch. If you can not find a van like yours, then look at those other cars you mentioned; pull out their switches and compare. That's about the surest way to find a match.
Old 08-28-2012, 06:21 PM
Jose A.'s Avatar
Jose A. Jose A. is offline
Jose A. is gaining momentum as a positive member of FTE.
that's a typical failure mode for those switches, the left and right or the up and down stop working. I tried to fix one but there is circuit board inside that burns out or shorts.
I have a good working one but the white "arrows" have been erased from use, also the grey plastic wiring plug needs to be matched to the harness plug in your van, they used a small plug and a large plug, I have both. can you take a picture of your switch and wires with the plug? (you will have to remove the door panel to remove the switch assembly, it is held by two 8mm nuts).
if you want it, pm me.
Old 08-29-2012, 10:36 AM
Thanks for the input.. Jose.. thanks for the offer!! However I am restoring this van, so I would love to find a switch in great shape. I have found several Mustang power mirror switches from 87-93 on ebay.. I just wasn't sure if they would fit. Sounds like I need to hit the scrap yards! The van is getting new sending unit in it to fix the gas gauge.. I'll have to wait until it gets back to see the back of it...
Old 08-31-2012, 02:56 PM
Jose A.'s Avatar
de nada.
here's a good piece of news and to return the favors that others here have done for me:
today I parked a Damon Challenger RV, and guess what? it has an identical power mirror switch like the Aerostar. The RV is/was made by Damon Corp.
check with Damon RV Parts Suppliers, they must have the replacement switch (less the metal mounting part, but you have that already). If you need more info from this particular RV, let me know, I have access to it.
Old 09-15-2012, 10:08 AM
I'm relying on your expertise here.. after scouring every single junk yard in the area, no power mirror switch is to be found.. I have found a number of them on 92-97... is there a way to rewire this to fit the connector in my 88? Or if anyone comes across one for an 86-88 in a junk yard.. let me know so I can buy it-- if it's in good shape! Another random question... are the 89-91 mirror switches the same as the 86-88?
Old 09-15-2012, 12:02 PM
MarylandAero MarylandAero is offline
MarylandAero is starting off with a positive reputation.
I'm looking for a switch for my '95 with little luck. Where did you find the later switches? Thanks...
Old 09-15-2012, 12:48 PM
Jose A.'s Avatar
I've owned Aerostar since 1986 when they came out. The power mirror Switch FACE in all three of them is identical, the differences are:
1) the wiring plugs at the end of the harness and at the door harness, (smaller plug in earlier Aerostar, bigger plugs in later Aerostar), but the wires are identical, so all it takes is changing your plug to a newer or older plug as needed. (the wires are removable from the plastic plug).
2) the circuit board under the switch's FACE is different in early switches, so you cannot exchange the circuit board from an early switch to a later switch. I already tried.
3) otherwise, the switches are identical on the outside, same mounting base, same two nuts, same number of wires.
I have a mirror switch with either the small or large plug. Pulled from a 1990 van. The < > arrows silkscreened on top of each switch pad and the text UP DOWN, has been "erased" or rubbed off from use. Otherwise it works fine in all positions in both mirrors. I tested it in my 1997 Aerostar recently.
If you want to buy it, send me a PM. Take a picture of your plug and send it to me, I will send you the switch with the correct plug.
Otherwise you'll have to go to RV Parts Suppliers to get a new switch, and I don't know how they configure the wiring plug. I only saw an RV with an identical switch mounted on the dash, and another RV with a similar switch that looked slightly smaller.
Old 09-15-2012, 12:51 PM
Jose A.'s Avatar
Quote:
all you have to do is remove each wire from the replacement switch and insert them into your old plug, the wire connectors are removable from the plug. you need a tiny screwdriver to bend the tabs.
Make sure you MARK each wire color in your old plug before removing them, otherwise the wire colors in a newer switch are the same as the old.
Old 09-15-2012, 04:57 PM
all the power mirror switches I've found are in Columbus Ohio.. sounds like I'll be heading back that way to see if I can get one again..... I've got the connectors out of the plug and labelled the plug for the colored wires... Hope this works!!
Old 09-15-2012, 08:25 PM
Muffinman Muffinman is offline
Muffinman is starting off with a positive reputation.
I'm going back to the junk yard Sunday, cause I found a cherry inside tan Eddie Bauer van. I'll check to see if its still there and all white letters still looking good. I tried to use a new gimbal control cause it looks so neat, out of an Eddie Bauer Excursion. I need to rewire the new harness to make it work.
I been taking every good part I can find all day today. I even got the captains chairs in the center row cause they fit where the old bench is now. Clean as new inside panels, headliner, all looks great for being a 1991. got the complete side door rollers in great shape, New cargo net,All the fuses, lamps, headlight lamps. It even had a new air filter, and Ford lower radiator hose in the back all for $16.00
Old 09-16-2012, 01:45 PM
Muffinman.. if it had it will you let me know? I'm going to hit the junkyards again to see if I can get a jack for the shorty.. and I'd love to find a cargo net... and the "electronic four wheel drive" badges for the 94..
Old 09-16-2012, 04:54 PM
I'll check it out Monday, It's been raining all day so it's muddy today. I'll check for the mirrors\window and door locks, while I'm there.
Old 09-17-2012, 07:20 PM
Here's the update... got a power mirror switch for a 96.. did some wire splicing.. and ta da!! Power mirrors again! I got a bunch of door clips... the power mirror switch, a slew of interior screws.. and the screw to hold the jack.. all for $5!!! Thanks to all for your help!!
Old 09-17-2012, 08:38 PM
I go back today and the damn thing got half the inside picked clean. least I got the rest of the parts I needed first. The seats, rear door shocks and door locks where gone. I was 'there early too. I did find 14' of #4 street wires under the carpet with a blade fuse block. Its mine now.
mirror help please dixiemudder04 2004 - 2008 F150 2 10-28-2016 12:06 PM
2003 F250 Power Mirror Problem ih2150red 1999 to 2016 Super Duty 1 08-27-2011 11:55 PM
Power folding mirror swap ZFamly 2007 - 2014 Expedition & Navigator 4 08-26-2010 02:06 PM
Manual to Power mirror conversion pflueger 1999 to 2016 Super Duty 6 05-10-2004 08:50 PM
Haunted Passenger Mirror (Moves on its own) FarmLaw 1997-2006 Expedition & Navigator 4 12-17-2003 09:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
