What kind of HP are you making ? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 08-28-2012, 10:42 AM
catman52987 catman52987 is offline
catman52987 is starting off with a positive reputation.
Exclamation What kind of HP are you making ?
I thought I would create this thread because I don't see a lot of posts about what kind of horsepower these trucks are capable of making. Over the weekend I attended Schied Diesel Extravangza. Curious as to what kind of horsepower I was making I decided to dyno my truck. My truck currently has a H&S Black Maxx with the 300 HP tune, a 4 inch Flo Pro with stock down pipe and a S&B cold air intake. I ended up dynoing on 2 dyno's back to back. The first dyno was Schied's mustang dyno. The truck ended up making 475 HP and 1261 ftlb tq. I let the truck cool down for about an hour and changed nothing. Then I put the truck on DP Tuners dyno. There, it made 597.8 HP and 1116 ftlb tq. I have no clue why I got results that were so different. Schied said it was because of the differences in the dyno's. Some of the other 6.4's had similar Results that I saw dyno. Mine however was one of the higher ones. Anyway, I just thought I would give everyone a heads up as to what these trucks are capable of and see if anyone had similar results.
Old 08-28-2012, 08:05 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I read somewhere that running diesels on a Dyno isn't the same as running gas vehicles. Not sure how and why, but that may explain your variances.
Old 08-29-2012, 01:27 PM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
Scheids I believe had Beans dyno and that dyno reads notoriously low. My truck running the Spartan 300 tune laid down 560 and 1170. 6.4s with big tunes will generally be in the 540-570 range with tuner, exhuast and intake. Reason they have to be done differently than gas is you have to load the dyno so the turbos will light to their full potential. If you aren't loading the truck, your numbers aren't going to be accurate.
Old 08-30-2012, 11:03 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
I've heard spartans 350 tune can put down really good dyno numbers,
but the 310 tune is a faster race tune.
Built 2V and 4V 400 dyno's suprisingly similar. nothercrash 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 40 02-21-2017 11:03 AM
Drag strip times in my OBS :) plgebbia 1994.5 - 1997 7.3L Power Stroke Diesel 17 09-17-2013 06:49 PM
Awesome day - but BUMMER of a Dyno Run!! :( CAT_man_963 1999 - 2003 7.3L Power Stroke Diesel 19 05-02-2006 09:20 AM
Finally got them posted! (KB supercharged V10 dyno numbers) kenneBF250V10 Modular V10 (6.8l) 22 08-04-2005 06:01 AM
V-10 dyno results CRJPILOT Modular V10 (6.8l) 2 06-04-2003 07:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
