Turbo Farts & intermittent Power
Old 10-02-2012, 06:54 PM
timberon94f350's Avatar
timberon94f350
timberon94f350 is offline
Now today,It had been sitting for about 16 hours. No DTC's on KOEO mode, & nothing about the MAF or EGR in KOER. (Dad revved it a couple times & took the MAF off when he cleaned the air filter. I think that's why it threw those codes?) However, it showed P2263 Turbo Boost Performance. Could the new turbo have went out??????????
Old 10-02-2012, 08:50 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
We have to separate the Bad DTC/Codes from the actual fault DTC
If he had Stuff unplugged and started the truck then its thrown a Bunch of BUNK DTC
We need to get it to a Point we know what DTC is legit and what what dont apply
So write ALL DTC Down at this Time
Then take and unhook Both Batterys ALL Cables and turn Headlights on for 30 minutes this will reset the PCM hook it all back up make shure EVERYTHING IS PLUGGED BACK IN BEFORE TURNING IGNITION ON
THEN DRIVE IT LET IT THROW ALL DTC AGAIN or get a Scanner that reads Live Data Like ScanGaugeII will do what youn need
I assume this DTC below is the problem However IDK The problem is when the MAF sensor was Unplugged it could have affected everything else down the Line
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 25.5pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=34 width=102>P2263</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>MAP</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>Turbo/Super Charger System Performance</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>CAC system leaks, MAP hose disconnected, exhaust system leaks, intake system leaks</TD></TR></TBODY></TABLE>
I take it you replaced the Turbo For the Turbo Farts and Intermittened Power am I OK to ASSUME THIS?????????????????????????????????????????????? ?????????
NO^^^^^
You have a Leak or Bad Sensor
Old 10-02-2012, 08:59 PM
timberon94f350
Yes sir, we put a new turbo on because it totally ran out of power going up a small hill empty, blew a bunch of black smoke, & "farted." THEN, it started idling real rough after we put a new turbo on it. Took it to the mechanic, who said 4 injectors were bad. He replaced all 8. I'll do the resetting of the PCM tomorrow. Thanks for all the help. I greatly appreciate it!
Old 10-02-2012, 09:06 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Sounds Like its Got a Leak or Bad Sensor
I dont think the Old Turbo was Bad because sounds like it runs like ***** still
Clean the MAP Hose its the Hose off the Passenger side intake manafold and hose runs to valve mounted by the Heater unit by the Cowl
Old 10-02-2012, 09:19 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Im thinking a 150.00$$ ScanGaugeII would have saved you 1000.00$$ Turbo
Old 10-02-2012, 10:11 PM
timberon94f350
Just ordered one. Probably too late LOL
Old 10-03-2012, 11:06 AM
timberon94f350
NO^^^^^
Ok, no koeo dtc's, but it showed p2263 in KOER before & after resetting the PCM. I made sure & drove it til it got to operating temp. So probably a MAP sensor?
Old 10-03-2012, 06:57 PM
timberon94f350
OKAY, NOW WHAT THE HELL?! It isn't showing an codes except my cruise control switch is causing problems? No codes in KOEO still. The scan gauge 2 will be here Friday or Saturday. Until then, I dunno WTF.
Old 10-03-2012, 07:41 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
have you cleaned MAP Tube and sensor with Carb cleaner Yet????
Does it run Better????
Some DTC will take Multiple Drive Cycles to set the DTC again
Old 10-03-2012, 08:03 PM
timberon94f350
Haven't cleaned either the tube or sensor yet. It just had low power that once (after injectors & turbo), but it "farts" every time Dad floors it. Sorry for any previous confusion. The mechanic who put the injectors in said not to worry about it & that "6.0s do that". I claim BULL puckey.
Old 10-03-2012, 08:15 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
well it will turbo Fart if the Pedal is to the Metal and then suddenly let off thats Normal there is NO WAIST GATE like the 7.3L so all the Air gets pushed back out the air Box
But if it FARTS while the pedal is held steady this is Not Normal
Old 10-03-2012, 08:22 PM
timberon94f350
Okay, Thanks VERY MUCH for your help sir!
  #28
Old 10-04-2012, 12:07 AM
mustangenthusiast34's Avatar
mustangenthusiast34
mustangenthusiast34 is offline
sounds like your coneuter valve is clogged.
  #29
Old 04-08-2013, 11:47 AM
timberon94f350
It turned out to be a MAP sensor. This helped for a little while. Then it started doing it again. So we (my father) replaced the Map sensor without reading the codes. Now it's back to fluctuating on power. For example we hauled pretty close to 10k 100 miles & it did okay. Then on the way back (empty) Dad said it "ran like sh#$". I just did a KOER & got PO1O2 (Mass or volume air flow circuit low input) & P1408 ( EGR flow out of self test range) I didn't get it up to operating temps or drive it & of course, being deaf, can't tell you what it sounds like. So I am asking for your help again.
  #30
Old 04-08-2013, 03:19 PM
timberon94f350
& it's showing no codes on the ScanGauge II
Quick Reply: Turbo Farts & intermittent Power
