93 f150 trouble starting
I need some help!!!!! I rebuilt the engine in my 93 f150 4x4 5.0L 302. i put the engine in the truck and it will not start. i have replaced the fuel pump the filter and the fuel pressure regulator and still nothing. it try to hit put nothing major. i have good fuel pressure and it is fireing on all cylinders. but will not start i also changer the egnition modual because i was told that that also controls the injectors. I don't know what else to do and sure would love some help
Oh it will start up with some starting fluid but goes dead quickly!!!!!!
<!-- / message -->
<!-- / message -->
It is a 302. I have tried both fireing orders but no differance i am trying to find a tester to make sure my injectors are fireing. the only way i have been able to get presure to the fuel rail was to plug the return line at the fuel pump. when i hook it back up to the pump the presure goes away.
Does it run when you block the fuel return line? If not fully blocked how about partially restricted? Say for example lightly clamp pair of vise grips on rubber section of fuel return line, so to simulate proper pressure reading?
Dual tanks or single?
If runs with return plugged or restricted and is single tank sounds like you need to check your work in the FPR.
<!-- / message -->
<!-- / message -->
The PCM (computer) controls the injectors via pin 58 and 59 at the computer.
Check fuse "I" in the "under the hood" fuse box to see if its burned out.
Next, try switching the horn relay with the PCM Power Relay (same under the hood fuse box) and see if it runs.
Bob
justinmilo31
09-20-2012 09:12 AM
Trucklover_45
08-27-2012 07:51 PM
