Go Back   Ford Truck Enthusiasts Forums > General > Projects
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #1 (permalink)
Old 08-27-2012, 03:55 PM
Carlene's Avatar
Carlene Carlene is offline
FTE Administrator
1964 Ford Falcon
My Garage
Carlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputation
Leather Seat Repair
First, here's a picture of the 1999 F350 we picked up a few weeks ago. Everything appears to work great and the outside is in good shape. The only real issue is (1) that it has Leather Seats and (2) that the seats were in pretty bad shape.
__________________
Carlene
FTE Guidelines
Check out the Florida Chapter
  #2 (permalink)
Old 08-27-2012, 04:07 PM
Carlene's Avatar
FTE Administrator
1964 Ford Falcon
My Garage
Drivers Seat
Now for the seats and how I spent my weekend.
I ordered the leather repair kit from Leather World Tech and was thrilled when it arrived at work Friday before I left. Means I actually had to get at this little project.
The drivers seat wasn't in that bad of shape so I'll start there.
You'd think after all these years that I've been on FTE I'd figure out how to post a picture with breaks so I could explain before/after each photo but here goes.
1st & 2nd picts are how the seat looked before cleaning.
3rd is after I cleaned it with the cleaner that came in the kit.
4th is after I put the crack filler and one coat of stain on.
5th is the finished seat after 3 coats of stain, a conditioner and protectant.
Almost forgot, after cleaning, I repaired the seam split shown in the 2nd pict with a product called Mend-It. It was an "as seen on TV" thing that I picked up a couple years ago and have used on many different repair projects. I like it better than super glue because it bonds fast but not too fast and so far I've had good results on fabric's. I'll let y'all know how well it lasts on leather after its had some miles on it.
__________________
Carlene
FTE Guidelines
  #3 (permalink)
Old 08-27-2012, 04:21 PM
Carlene's Avatar
FTE Administrator
1964 Ford Falcon
My Garage
Passenger Seat
Don't ask me why but the passenger seat was in much worse shape.
The large hole isn't as perfect of a repair as I'd like but I didn't want to trim any of the seats foam and I'm on a time limit to get everything done because hubby is getting new denim seat covers put on this coming Friday and the repair & protectants need time to cure.
Pictures are as follows:
1. Seat as it came from prev. owner.
2. Seat with repair backing.
3. Small hole with patch piece in place. This one turned out great.
4. Large hole with patch in place. This one I'm not happy with.
5. Seat with crack filler on. This stuff is much easier to work with than bondo and very flexible.
6. Seat after 3 coats of stain, conditioner and protectant. Did I mention that I'm not all that thrilled with my shotty patch work but its still better than without the repair and won't rip the new seat covers.
__________________
Carlene
FTE Guidelines
  #4 (permalink)
Old 08-27-2012, 04:25 PM
Carlene's Avatar
FTE Administrator
1964 Ford Falcon
My Garage
Steering Wheel
Well, this one wasn't in my plan but when Steve took the cover off the steering wheel there was a nice gash and worn spots on the top of the wheel. Since I wasn't prepared for this repair, I didn't have the right color stain so I two-toned it. Top & bottom are the same color now as the seats. It actually looks very nice and as if it belongs.
__________________
Carlene
FTE Guidelines
  #5 (permalink)
Old 08-27-2012, 04:30 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
2002 Ford Ranger
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
Looks great!
__________________
Joe drives an 02 supercab shortbed 3.0 liter automatic power nothing Ranger Edge.
Joe's wife drives an 06 5.4 liter 3 valve, automatic 4x4 power everything Eddie Bauer Expedition.
BC Chapter Member
  #6 (permalink)
Old 08-27-2012, 04:40 PM
Carlene's Avatar
FTE Administrator
1964 Ford Falcon
My Garage
Now for some of the little things none of the leather repair kits or websites or video's I've researched prior to tackling this project tell you.
1. The kits do not come with enough crack filler to do as an extensive repair as what I just did.
2. The repair kit comes with plenty of cleaner, protectant and stain to do the 2 front seats.
3. If you have to do the back seat also, you will need another 8 oz bottle of cleaner.
4. If you have any type of grain that you wish to try to duplicate, they have a seperate filler for that. I can't tell you anything about that because I personally like the smooth look.
5. I only used 320 & 400 wet/dry sandpaper and used it dry only. I didn't want a mess all over the interior of the truck from wet sanding. The dry sanding worked great and I was surprised at how little mess there was.
6. Definately keep a blow dryer, not heat gun, plugged in. It helps cure the back patch glue, crack cream and stain so much faster.
7. Buy the additional protectant/sealer designed to protect from denim if you have light colored seats.
8. Don't show anyone you know your repair - they'll all want you to fix their seats to - ask me how I know.
All in all, this was very easy to do. I spent about 2 hours Friday night giving the seats a good cleaning, about 4 hours Saturday night fitting the patches, gluing in the backing at all holes & rips and putting the 1st coat of filler on. Sunday was a bit longer day. I tweeked the easy repairs in between doing light coats on the major repair areas, stained, conditioned and protected. This was about 9 hours (6 if you take out for eating & smoke breaks).
Thats all I can think right now.
I'll post back after we get some miles on the truck and seats and let you know how that large patch repair and the drivers seat seam holds up.
__________________
Carlene
FTE Guidelines
  #7 (permalink)
Old 08-27-2012, 06:53 PM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
Garage is empty, add now
FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.
Carlene, that is very cool. It escapes me as to how such a clean looking truck (outside) could vary so much on the inside.
Your final comments/suggestions leave me questioning... On my 11 SD I have leather seats. The drivers side is already looking 'worn past its age'. So what is it about denim and leather that I need to know/use?
  #8 (permalink)
Old 08-27-2012, 08:18 PM
Carlene's Avatar
FTE Administrator
1964 Ford Falcon
My Garage
Thanks guys.
Herman, It escapes us too as to how bad the seats were. Only thing I can figure is that they never conditioned the leather. The rest of the interior is almost perfect, including the carpeting.
As for the denim, every site I researched specifically mentioned denim due to the denim transfering color and fibers to unprotected or unmaintained seats. I would imagine denim is specifically mentioned because who doesn't wear jeans?
Here's a good read about leather.
http://www.vettelegends.com/data/Leather_REV5.pdf
__________________
Carlene
FTE Guidelines
  #9 (permalink)
Old 08-27-2012, 10:58 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
ctubutis ctubutis ctubutis
Wow...
What would you do for this? Mend It?
__________________
About the bra
  #10 (permalink)
Old 08-29-2012, 11:00 AM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Can I assume you used the Leatherique system you linked to? If so do you use one of their kits or did you piece your own together?
My seat bottoms are decent as they've been covered for 11 years, but the seat backs and arm rests are in desperate need of some attention.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #11 (permalink)
Old 08-29-2012, 11:29 AM
Carlene's Avatar
FTE Administrator
1964 Ford Falcon
My Garage
Scott, This is the kit I bought, actually bought 2 kits to make sure I had plenty of stuff to get it done over the weekend and couldn't find anywhere or anyone to tell me how much of everything I needed. I could have gotten away with 1 kit and 1 extra thing of leather filler.
Deluxe Leather Repair and Recolor Kit by Leather World -
I also bought the Barrier product to give the seats extra protection since they are going to have denim seat covers on them.
Leather Master Leather Barrier -
I went with the kit above because it came with the color match stain. Many of the leather repair kits I've researched cost extra to get the color match.
Chris, I'd say go the same route I did, what do you have to lose - its much cheaper than having it reupholstered and if you don't like the results, you can still have it reupholsered. It was very easy to do. What took the most time was waiting for the leather filler to dry.
__________________
Carlene
FTE Guidelines
  #12 (permalink)
Old 08-29-2012, 12:30 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
Very nice. Thanks!
__________________
Scott
  #13 (permalink)
Old 09-02-2012, 12:21 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud ofm-chan68 has much to be proud of
ctubutis, your avatar just about made me fall off my chair!!!!
Carlene, good job on the leather seat repair. Thankfully, my 2007 F-250 is an XLT with cloth seats. To all you Super Duty truck owners, with the Lariat leather seat interiors, suck it up, this happens to just about ALL these trucks whether it's a 1999 or 2013 model year. The problem is with how high these trucks sit, and after so many entry and exits we all tend to rub off the outer seat bolsters with a lot of force just due to the way it's curved. There's really very little that can be done to prevent this from happening, other than putting a concerted effort into NOT rubbing on the outer bolsters of the seats when getting in and out. But are we going to tell everyone to do this? Likely not. And what about the times when you are parked in a tight parking spot where you have to pay attention NOT to hit the vehicle beside you with the door while you're getting out of your truck?
It's just like the question I always wonder. How many of you hit your heads on the exterior mirrors of your trucks? More importantly, do you ever wonder how passers by will hit their heads on the mirrors of our trucks when we're parked in parking lots where the spaces are designed only to accomodate an average sided car? Sorry for the hijack.
__________________
http://www.yorkdaleford.com/service.html[/url]
Ford Diesel/Senior/Master Tech
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
