Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
- Tires General Information/Maintenance
Important information to help you understand your Ford truck
1950 F1 Wheel/Tire Advice
Thanks Topper & Tip,
I'm just trying to soak in all the different ideas & approaches to this tire/wheel dilemma. This one is frustrating as all I need is just an inch or two & the front tires will sit inside the fenders & all will be good with the world... Tough to spend $800 just to get an inch or two.... Grrrrr. There is also the "makes you feel stupid" aspect as you think through how you got here.
My current front tires are 255-45-18's - according to those neat little calculators above that's a 27 inch diameter with a 10 inch width - not happening. The 215-45-18's suggested by Dmack above would give me 25.6 inch diameter at 8.5 in. width but a very firm ride. Hmmmm...
I think the 8.5 inch width is what I really need - a skinnier tire/wheel to pull the tires inside the fenders.
Ben in Austin
Ben in Austin
Ben,
Just keep in mind that if you keep the current rims, if you reduce the tread width by 1.5", it will pull it 3/4" in on both the inside and outside of the rim.
I really don't think you would feel much difference going from a 45 to 40 series tire. Stiff is stiff (pardon the insinuation).
Good luck with the project. You are really close (much closer than me).
Dave
Dave
I'm also playing with the rim / tire thing; have MII IFS with Explroer rear.
I had Ford 15" rims (4.5" backspace) on my "roller" but didn't have the clearance on rear tires so I went with late 80's 15" rims (3.75) and am shopping for tires (185 70R 15) which are about 26" diameter.M y front Is lower than I would like with 8.5" clearance on front bumper. Tried taller springs but didn't raise front height; will try later. Right now 'm concentrating on getting registration.
Ben in Austin
Ben in Austin
Ben,
One other thought to get it aligned. Not sure what bolt pattern you are running (explorer?), but if you have a friend/co-worker with a vehicle with the right bolt pattern with a regular size tire, you could talk nicely to them and swap front tires/rims long enough to get it to an alignment shop and have it aligned.
I would think it would work as caster and camber are measured in degrees, so height/width of the tire should have no effect on their settings and readings. I believe toe in is in inches, but only the overall tire diameter would make a difference, but I would think would be negligible and at least let them get you very close.
Dave
Dave
I don't know anything about the mustang II ifs, but I seem to remember a thread here.
Other guys here hopefully can answer this. I thought you can buy shorter or longer control arms? If you could buy shorter ones, that would suck the tire/wheels in the fender. I don't know if that is cost effective or not.
Hey Guys,
Our truck looks great but still needs some TLC to actually drive great.
We've got a 1950 F1 with a 351W/AOD as a drivetrain & a No Limit Coilover IFS up front with an Explorer rear end. The truck has 2,000 miles on it since returning to life.
The existing Tires/Wheels on there are 255-45-ZR18's Dunlop Direzza's.
They fit fine out back with 2 inch spacers - but up front they are just too big! Alignment places can't do anything as the tires sit too close to the fenders. The front tires are splayed out in front - looks like the truck went over a jump .... So how do I get out of this predicament?
o Same style wheels are $250 ea plus tires @ $150 - $800 to replace the front wheels/tires with 17's? 16's? That's pretty pricey ..
o Can I run 16's on the front & 18's on the back?
o Get some more period correct looking wheels?
o Can I put "smaller" skinnier tires on the same wheels? What offset do I look for?
Just looking for general wheel/tire advice? What would you do? (My 20 year old Zack picked this style wheel - I'm not sure I want to keep buying more of them...).
Ben in Austin
Ben in Austin
In doing a Google Image search scheming for Frank (isn't that how everyone spends a Friday night?) I came across yours (beautiful, btw).
Do you have a straight - side shot? And what size rims and tires did you end up with? I'm trying to plan mine out, even though I'm a ways out.
Thanks!
Hey Christiansen,
Here is a side shot. Let me look at my notes & I'll post the tire/wheel info.
tomorrow. Our suspension may not be the same as your's - we've got a Mustang II up front & an Explorer 8.8 in the back.
Ben in Austin
1950 F1
(I've got more pics on an external harddrive but it's been acting up lately ... a weekend project to sort it out). I'm sorry this pic is sideways - another mystery to sort out).
Ben in Austin
1950 F1
on
I don't like to be the pessimist but it looks to me as the offset on your front rims is too much you will gain a little on tire size but the rims are simply out too far . Are the fronts and backs the same ? You mentioned 2" spacers on the rear I've never heard of that big , and you have none in the front correct ? On the good side your splayed out look is camber adjustment and when you can get it aligned they should be able to sort that out
Hey Ebear,
Nothing is ever perfect on these old trucks has been my experience.
We've got 20K miles on it...not bad for an old truck. We do have spacers on the back - that kind of comes with using the slightly narrow Explorer 8.8 in axle - you get good gears, disc brakes, posi., lower stance, etc. & you have to use some spacers to get the tires set up in the wheel well better. (I can't remember 1.5 - 2.0in. spacers).
The front wheels are little large for the truck & we had some rubbing so we had to go with really low profile tires. My 24 year old son likes that hotrod look - me not so much.
I don't really like the front end set up too much either... something not quite right. Hard to align, small profile tires, etc. When Zack moves on from college I'll sneak in there & get smaller diameter wheels & higher profile tires. I really don't want to tear out the Mustang II front end
so we live with a few nagging issues - this suspension wasn't made in a factory but it works for us.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
ALBUQ F-1
22
08-06-2015 08:52 PM
xxxcre10xxx
13
12-15-2002 12:13 AM
