F250 Brake Bleeding ???
Old 08-27-2012, 03:26 PM
mgfuns's Avatar
mgfuns
mgfuns is offline
Hi Everyone...
92 F250 w. 351W. Finally got my air pump all sorted out.
A little while ago I got in the truck only to have the brake pedal fall to the floor. Went underneith in the back and noticed just how badly corroded my lines had become.
This truck is a firewood hauler and not my DD by a long shot so it gets back burnered frequently when it needs things. A week later I got new lines and installed them in the back.
A week later I got a pump tank type bleeder machine from a friend. I proceeded to pump to 10 psi and bleed the brakes this weekend, working the back first (where the line was broken) and then the front.
Still getting quite a bit of squish. If the lineswere open for a while does that just mean that a lot of air probably got in? How long do I need to bleed for when it seems like just fluid is coming through?
If bleeding doesn't fix anything what's the next step? The master cylinder?? Everything worked well before this .
Thanks,
Mike
Old 08-27-2012, 04:04 PM
blue95f250460's Avatar
blue95f250460
blue95f250460 is offline
you likely still have air in the lines. Could also be a bad brake booster, check valve or master cylinder. Did you flush out the old lines too? if not buy a couple bottles of fluid and do that as well.
You need to bleed the lines until you no longer see bubbles coming out, depending on the length of the line it can take a bit of time.
Old 08-27-2012, 04:17 PM
andym's Avatar
andym
andym is offline
You also have to bleed the ABS valve. The order is: RR, LR, ABS, RF, LF.
Does the pedal slowly sink to the floor, or is it just mushy?
Did you adjust the rear shoes correctly?
Old 08-27-2012, 04:28 PM
mgfuns's Avatar
mgfuns
mgfuns is offline
The pedal basically slowly sinks to the floor and then once you shut the truck off you can basically pump it back up.
I probably only ran about 12 oz of fluid out...maybe even less.
I have plenty of brake fluid it's just I ran them all and got pretty decent looking fluid coming out and not a lot of air after several seconds each. I realize now that this probably doesn't mean much of anything. So in effect I didn't really "flush" anything. I guess I should.
Did not know re ABS bleeder valve. And I also didn't do anything with the shoes.
I apologize if a lot of this stuff is basic knowledge.
Thanks
Mike
96f150
1997 - 2003 F150
06-10-2018 08:52 AM
gbeach
19
03-28-2014 02:40 PM
2112
1999 to 2016 Super Duty
20
07-31-2012 10:43 AM
tuke
09-15-2007 02:00 PM
pokerpuller
05-22-2006 02:44 AM
Quick Reply: F250 Brake Bleeding ???
