Alternators from the "Zone"
Last year while on vacation in Ennis TX the alternator went out on my truck. Well, the only place in town that could get one quickly was A-Zone Replaced it in the parking lot and was on my way to Galveston, that one didn't make it to Houston before it quit charging. Replaced again in Galveston the next day. That one ran until I got to Vancouver WA and discovered the rear bearing out while Dano78 and I were working on my transmission leak. Well.... launched my boat yesterday and the truck wouldn't start again, had to pull the battery out of the boat to start it These are 55A Bosch alternators and I know that my truck doesn't overload them
I am off to get another one today, and you can bet your sweet *** it will not come from the Zone. Wonder if they'll give me my money back on this POS
Yeah, they'll refund the money (usually). Are these the 1-yr warranteed or the lifetime? About all they do to the 1-yr ones is clean, test, and paint them, maybe new brushes. The lifetime models get new bearings and some other parts. But it seems like cheap chinese bearings are used in all of them any more.
I've never understood Bosch, how does it take up to 7 wires for their alternators? And why does a rebuilt 50-amp Bosch alternator cost 4X or 5X what a 100-amp Delco or Autolite costs??
I can sympathize with you. I once replaced the alternator on my wife's car with a warrantied one from a local chain store. The next day she was running errands on her lunch when the car died and started making noises. I had to take my lunch time to meet her where the car died. I found that the pulley nut had come off and was nowhere to be found. So we both had to miss time at work so I could go get a replacement (with a tight nut) and replace the "new" alternator.
After that whenever I needed a starter or alternator rebuilt I just went to the local rebuilder and handed them mine. 20 minutes later they handed it back with new bearings, brushes, etc. and I was on my way since I could paint it myself.
Plus the local guy gets the money. Although you are taking work away from the 12 year old Chinese girl making the inferior bearings and brushes; and the illegal immigrant working at the Autozone rebuilder shop installing those inferior parts.
A friend of mine with a 79 f100 had a pretty bad experience with alternators from the zone. At the zone he'd buy it, pull it out of the box and have them test it. He went through 6 or 7 that way before he gave up and drove to napa!
Any work I need get's done by a local shop, they specialize in radiators starters and alternators. They've got great parts, great prices and great turnaround times. Can't beat that!
Sam
Sam
I've worked aftermarket style parts stores for nearly 10 years. Most of the time, an aftermarket or rebuilt unit works fine. On newer cars I seldom see one walk back in. I often pull from the shelf and bench test prior to the sale though, and I have pulled a few off the shelf that were bad. It happens, I don't care if it is a skilled craftsman or a 12yr old in a sweat shop...mistakes are made.
Anything vintage, order only, or difficult to find I refer to the local alternator rebuild shop that has been around longer than I have 100% of the time. Even with new units, 80% of the problem lies in the regulator...but most of them quit supplying just the regulator to us which basically forces a consumer to buy the whole enchalada or have it rebuilt. Honestly 90% of my customers wouldn't or don't take their OE parts to be rebuilt even after I inform them about their options. They would rather order it.
I do the same for starters, radiators, generators, alternators, power steering pressure hose, brake hose, hydraulic pressure hose, electric pumps, winches, AC condensors, AC compressors...there is a huge list of parts that can be rebuilt locally that many take advantage of and I advertise often. Tough Guy, Heatex, Elkhart Starter, Action Machine, Kaley's...I love telling people about them because they do great work. I also try to sell rebuild kits for wheel cylinders and master cylinders more often than not.
I recently had similar experiences with electrical parts from the Zone. My son and I installed 3 electric fuel pumps in his Ranger. The longest one lasted 3 weeks. I ended up getting my money back from the Zone and went over to NAPA. Its been running fine ever since.
Lifetime warranty sounds good, but it sure doesn't cover my hours and frustration to keep replacing the part in question.
Good luck with it
Bobby
Good luck with it
Bobby
Lifetime warranty sounds good, but it sure doesn't cover my hours and frustration to keep replacing the part in question.Good luck with it
Bobby
Bobby
I learnd 40 years ago not to buy rebuilt items from any of the "lowest price" type of chain stores, the name of the stores have come and gone over the years but IMPO its still the same. I got tired of going thru three starters b4 i got a good one. Personaly id rather get a new part and know its as good as new, specialey when its going in my truck. Jeff, sorry to here you got stuck on the road and put in that position, thats a drag
