Need Help - Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
Need Help
Old 08-27-2012, 05:35 AM
Sara Boggs Sara Boggs is offline
Sara Boggs is starting off with a positive reputation.
Unhappy Need Help
I am in need of some help! My '2000 Ford Explorer XLT will only shift into drive if you start the thing up in neutral!!! Why is this and what needs to be done to fix this?? This is every time you put it in park you have to turn it of and back on in neutral!
Old 08-27-2012, 08:56 AM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Hi Sara and welcome to FTE! I don't own a Ford Explorer, but I would think the neutral safety switch is the first thing to check. Also, what does the shifter feel like when you take it out of Park and shift it into a gear? Is it loose? Can you get any other gear besides Drive? What about Reverse?
Old 08-27-2012, 09:09 AM
rywegh's Avatar
rywegh rywegh is offline
rywegh has a good reputation on FTE.rywegh has a good reputation on FTE.
I think John is on the right track... not sure with your year but it might also be call the VSS. thats what it was on my 99 ranger.
Old 08-27-2012, 10:08 AM
Red face
Unless it is started in neutral it won't shift into any gear! When started in neutral though the arrow that moves when the shifter is moved is in between gears not right on so you gotta count more or less to know what gear you are in.
Old 08-27-2012, 10:18 AM
It may be the shifting linkage is loose or worn. I haven't looked on a Ranger or Explorer, but the linkage in the steering column may be the problem. It could also be underneath. Be sure to have the wheels blocked should you climb under your vehicle. A 2nd person would be a big help in finding the problem perhaps. One working the leaver while another in underneath looking. Like I said, be sure the vehicle won't roll when doing this!
Old 08-28-2012, 01:52 PM
rywegh's Avatar
Sara, The VSS or neutral safety switch/ Range sensor runs about $40. on rockauto.com Autozone online manual says the sensor is mounted on the tranny, this is different from the ranger it was mounted on rear axle above the pumpkin. ask around in the ranger/explorer forum and a few members there can walk you through diagnosing and how to replace it.
need help Sara Boggs Explorer, Sport Trac, Mountaineer & Aviator 8 08-28-2012 12:04 AM
neutral safty switch jville 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-19-2009 05:29 PM
Shift Lock out broken nosagroy 1999 to 2016 Super Duty 4 04-03-2009 07:47 PM
97 ford taurus bambam634 General Automotive Discussion 2 01-24-2008 04:41 AM
Neutral Safety Switch on F350 theklutz13 1987 - 1996 F150 & Larger F-Series Trucks 2 08-13-2001 12:18 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
