windshield wipers don't stop - Ford Truck Enthusiasts Forums
Old 08-26-2012, 10:16 PM
donmi donmi is offline
donmi is starting off with a positive reputation.
Hi there,
Today I figured out, that my wipers don't stop working after starting the wash/wipe "procedure". (until I switch the ignition key to off)
If I turn the wiper on (without wash) and switch it off, the wipers are stopping somewhere on the windshield, they don't go to the "end"
I was looking for a relay, but after changing this in the fuse box no change.
Somebody an idea??
Michael
Old 08-26-2012, 10:25 PM
vfelix702's Avatar
vfelix702 vfelix702 is offline
vfelix702 is gaining momentum as a positive member of FTE.
Could be the switch itself.... my exprince with that.. wipers wouldnt shut off... then the intrmidinte black box that parks and delays the wipers caught of fire under the dash and it was scary lol i was driving and all of a sudden the truck died and i had a dead short at a in-line fuse wire type burned up by the battery coming off the starter selinoid.... i went to shut my wipers off and the switch fell apart then the black box caught fire all in about 15 secs.... so start with the switch then look at the intermidate box.... it is a soilid state control....
Old 08-26-2012, 10:32 PM
ihateminimumwage's Avatar
ihateminimumwage ihateminimumwage is online now
ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.
It's the switch. Mine didn't work when I bought the truck, found the motor was bad, replaced it, and my wipers will stop mid-wipe if I turn the switch off. Still need to fix it, just hasn't been an issue with the drought. I just got really good at timing when to turn them off.
Old 08-26-2012, 10:36 PM
vfelix702's Avatar
Ha me 2 i just wired in a spst toggle switch... and its been that way for 2 years.... well the other side of my toggle switch is monentary for the wash pump...
Old 08-27-2012, 04:55 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
For some reason the system won`t let me link you to the info, so I will try to explain what to do.
Go to the `87-96 F-Series page and open it, at the top of the page click on "Tech Info" and when it opens click on "No Cost Intermittant Wiper Fix".
May help.
Old 08-27-2012, 12:43 PM
you mean this here:
http://www.ford-trucks.com/forums/53...ml#post4059339
Very good!!
I will try this today
Thanks for your good memory.....
Old 08-27-2012, 12:44 PM
I think I'll also be doing this today! Thanks!
Wipers an switch problem WW2N 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-26-2016 09:11 PM
Wipers Don't Work Icefan71 1997-2006 Expedition & Navigator 10 02-08-2013 02:58 PM
Windshield Wipers Don't Turn Off Captbs32 1978 - 1996 Big Bronco 9 01-12-2012 11:51 PM
Wiper Motor Stays On Monzter Kuztomz 1999 to 2016 Super Duty 17 07-18-2011 12:18 PM
windshield wiper problems don9235 2004 - 2008 F150 4 07-15-2011 02:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
