Cleaning throttle body and intake manifold
Old 08-26-2012, 06:23 PM
pdqtimetrialer's Avatar
pdqtimetrialer
pdqtimetrialer is offline
I have a '95, 4.9l and pulled off the throttle body and intake manifold as part of the process to change the fuel injectors.
Both the throttle body and the upper intake manifold have carbon in them. I've seen posts suggesting soaking the manifold in mineral spirits to loosen the carbon. But given the size of the thing, it will take a couple gallons in a large bucket to be able to do so. Is there an easy spray available that doesn't harm the original surfaces? Does it matter after 200k miles?
Old 08-26-2012, 07:59 PM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
Get some throttle body/intake cleaner. Works well.
Old 08-27-2012, 02:09 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
An old tooth brush or bottle brush works great too. The throttle body and intake cleaner works well, but sometimes isn't quite enough. I know most people say not to use carburetor cleaner on these parts, but I've done it many times on several vehicles.
For the intake, I've used engine degreaser and the water hose too. I'd probably do this first, and possibly a second time, before using spray cleaner. You'll get more crud out of it.
Old 08-27-2012, 07:17 AM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
I use a pressure washer to clean out my intakes(off the truck of course). With the I6 EFI upper intake design, its a pita to clean out!!!! I fill mine up with engine degreaser for a few days before blasting with the pressure washer.
Stockbuilder
1983 - 2012 Ranger & B-Series
10-04-2014 09:33 PM
jwirth
02-08-2007 09:36 PM
J7Bones
15
10-17-2005 07:31 PM
jpw
16
06-19-2004 10:13 AM
BlueOvalFitter
11-29-2002 03:32 PM
Quick Reply: Cleaning throttle body and intake manifold
