Cleaning throttle body and intake manifold - Ford Truck Enthusiasts Forums
Old 08-26-2012, 07:23 PM
pdqtimetrialer's Avatar
pdqtimetrialer pdqtimetrialer is offline
pdqtimetrialer is gaining momentum as a positive member of FTE.
I have a '95, 4.9l and pulled off the throttle body and intake manifold as part of the process to change the fuel injectors.
Both the throttle body and the upper intake manifold have carbon in them. I've seen posts suggesting soaking the manifold in mineral spirits to loosen the carbon. But given the size of the thing, it will take a couple gallons in a large bucket to be able to do so. Is there an easy spray available that doesn't harm the original surfaces? Does it matter after 200k miles?
Old 08-26-2012, 08:59 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Get some throttle body/intake cleaner. Works well.
Old 08-27-2012, 03:09 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
An old tooth brush or bottle brush works great too. The throttle body and intake cleaner works well, but sometimes isn't quite enough. I know most people say not to use carburetor cleaner on these parts, but I've done it many times on several vehicles.
For the intake, I've used engine degreaser and the water hose too. I'd probably do this first, and possibly a second time, before using spray cleaner. You'll get more crud out of it.
Old 08-27-2012, 08:17 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
I use a pressure washer to clean out my intakes(off the truck of course). With the I6 EFI upper intake design, its a pita to clean out!!!! I fill mine up with engine degreaser for a few days before blasting with the pressure washer.
2.0 GDI engine issues SidecarFlip Transit Connect 24 04-17-2016 09:50 PM
Cleaning upper intake manifold Stockbuilder Ranger & B-Series 1 10-04-2014 10:33 PM
Intake manifold cleaning ChristopherN 1987 - 1996 F150 & Larger F-Series Trucks 5 05-27-2011 09:10 AM
oil in the intake manifold 2005f-150 1987 - 1996 F150 & Larger F-Series Trucks 16 04-22-2011 09:04 PM
Throttle Body Intake Elbow Needed lovemyexpy Expedition & Navigator 19 10-29-2010 05:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
