1992 F-150 6cyl. 300 inline 2 WD
In general, vacuum will only be present while running. The exception is if you measure at the vacuum hold canister. It was intended to hold vacuum for some of the accessories. I bypassed mine years ago when it began to leak.
How high is "high idle"? Does the idle speed drop when the engine warms up?
The truck may run smoothly even if the timing is off. Do you hear any knock under load or acceleration?
I'd still check the wires just to be sure.
Is the check engine light on? Always best to start with pulling codes.
Once again, a high idle indicates some sort of a vacuum leak.
A vacuum leak will cause an engine to run lean.
A lean engine runs hot.
Try unplugging the Idle Air Control (a.k.a. IAC) valve located on top of the throttle body and see if the idle drops back down to about where it should be.
If so, you have a sticking IAC.
Checking for trouble codes is highly advised as well.
Let us know what you find.
Bob
1992 F-150 over heating very high idle
Ive changed the air idle speed control. the only code thats being set is 332. thats with the KOEO mode. Ive checked all the vac. lines i can see but ill go over it again. I dont have a tach but the idle is pretty high it,ll get going 10 or 15 mph without me touching the gas pedal but just by sound if im on the brake it dont sound real high, if that makes any sense. i,ll chk those vac lines again and im going to chk. the line going from the egr to the exaust an see if thats clogged. ill get back to you guys shortly. I sure appreciate your help and input.
You did say "and a bunch of other stuff and then cleaning intake"
Did you remove and clean the EGR valve as well ?????
Bob
Yes. In detail i replaced ,Plug wires plugs,Dist.Cap,Rotor button,Air idle control valve,EGR valve .Idle pos. sensor. None of this stuff helped the sluggish running. So I took the intake manifold off cleanedit cleaned the throttle body very good . put every thing back together. The sluggish running was fixed runs good except the high idle & over htg. so i took the t-stat out . Didnt help. I also took the 2 solenoid valves off and cleaned best i could that control the EGR. They are both elec.& vac. operated. But i can take them completely off and theres no change at all. Could the tube that goes from EGR down to the exaust be clogged and cause this. When i first start the truck the idle is so high that the valves rattle for a second before the oil is lubricating them im afraid its going to burn the valves or something
Also changed the fuel filter, then the fuel pump, and fuel tank. Also cleaned fuel injectors,an changed o-rings and caps on the injectors. I believe this was the original problem causing the sluggish running. Sorry i keep adding stuff instead of putting all in one msg. but ive been typing so much and thinking about this dag gone thing im starting to lose it. thanks again.
Depending upon how you cleaned the EVR solenoids or how they were "re-hooked up", you may have damaged or changed their ability to function correctly.
Additionally, there should be a small blue disk item (one way vacuum check valve) that has to be oriented in the vacuum line correctly.
That check valve is most likely located at the back side of the valve cover near the firewall.
Double check the "coffee can" to make sure it holds vacuum too.
Re-visit all of that "vacuum system" and I'll bet you'll find your solution somewhere in there.
late edit: Here's a link to a like problem: https://www.ford-trucks.com/forums/6...egr-valve.html
Pay attention to what subford (Bill) has to say, he's da' man !!!!
Bob
Hey Thanks Bob
I know what those chk. valves look like theres not one on there. I took the lines off at there con. without bothering any part of the line those have like boots that slip on the valves and ive had all that out before. But Ino what you mean by cleaning the solenoids. Ill chk that cannister and get with that other guy. i really appreciate your help, when i get it fixed ill let you no. thanks Jeff
Yes the fan works No oil in radiator.
It was running fine until one day it just started running real sluggish like it wasnt getting enough gas. thats when my problem started, and i started doing all the work. It never overheated until I got it running good again .
Im pretty sure its running lean causing the overheating & High Idle.
Sundance Kid
01-28-2010 11:21 PM
CyFan
10-02-2009 05:48 PM
96onefifty
11-29-2007 07:20 PM
N7ghtwolf
16
06-02-2006 02:28 PM
