Exhaust question? - Ford Truck Enthusiasts Forums
Exhaust question?
Old 08-26-2012, 12:48 PM
FORD-or-Die's Avatar
FORD-or-Die FORD-or-Die is offline
FORD-or-Die is starting off with a positive reputation.
Question Exhaust question?
i have a 94 f150 5.0 2wd wanting to know a good size diameter for exhaust pipe 3 or 4 inch?
and does what is a good brand for a catalytic converter?
Old 08-26-2012, 12:55 PM
Puddy's Avatar
Puddy Puddy is offline
Puddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to behold
3 in, you still need a lil back pressure to run correctly
Old 08-26-2012, 01:31 PM
norfolknova norfolknova is offline
norfolknova is gaining momentum as a positive member of FTE.
I would say for a stock 5.0 stick with 2 1/2"
Matt
Old 08-26-2012, 01:39 PM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
no bigger then 2.5 unless serious engine mods are in your future plans.
Old 08-27-2012, 02:25 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Are you talking about single or dual pipes? I would say a single 2.5 or 3 inch and for dual pipes go with 2.25.
Magnaflow makes good replacement cats, so does Catco. There may be better ones, but these are better than most.
Old 08-27-2012, 12:34 PM
I don't think i have the money for a dual, going with single and just wanted to make it rumble a little louder!
Old 08-27-2012, 03:06 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Ditch the muffler and just run the tailpipe off the cat. That will make it louder. They make cat back systems that basically do that.
Kinda like top of this page:
Truck Parts and Truck Accessories
Kinda pricey, but you could have something made up yourself.
Old 08-28-2012, 01:26 AM
bigblockfever's Avatar
bigblockfever bigblockfever is offline
bigblockfever is starting off with a positive reputation.
my buddy has a 1986 f-150 single cab short bed and all he has done for the exhaust is put a flowmaster 40 on the cat and turned it out before the rear wheel. now thats an awesome rumble!
Old 08-28-2012, 04:07 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Don't go any bigger than 3" behind a small block gasser. But 2.5" duals would be plenty, and a 3" single would be just fine too. With big pipe like 4" you lose a lot of the scavenging that you get with the smaller pipe. But too small of pipe and you create back pressure, which you want to eliminate as much as possible in a gasser.
If you don't get smog tested, you could just cut the cat off and run a flowmaster or similar muffler. I'm kinda partial to Flowmaster mufflers, but whatever your preference is.
Old 08-29-2012, 01:03 AM
woodstock4130's Avatar
woodstock4130 woodstock4130 is offline
woodstock4130 is starting off with a positive reputation.
just did a 2.5 " Magnaflow on mine also with a new cat from Magnaflow(A.K.A Carsound) .Sounds nice and quiet at idle but when you get on it, gets nice and throaty!
runs alot better too.
Single exhaust out the back
Old 09-01-2012, 04:56 PM
busch6062's Avatar
busch6062 busch6062 is offline
busch6062 is starting off with a positive reputation.
I had an 4x4 1985 5.0 4-spd manual, that I cut the cats off, and put 2.5 duals with glass-packs on. Cost me about $200 out the door.
Old 09-01-2012, 09:04 PM
Hutch17's Avatar
Hutch17 Hutch17 is offline
Hutch17 is starting off with a positive reputation.
The exhaust in the truck im getting rusted off at the back of the cat, Im keeping it short sweet and simple! walker dual into one universal cat into a cherry bomb extreme muffler with a 12inch turn down out of that, pops out right before the rear axle. everything is ganna be 2.5 inch tubing
Exhaust ROKRAWL 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-07-2013 12:19 AM
exhaust juni88126 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-08-2010 06:56 AM
exhaust jmmartin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 03-13-2009 07:46 AM
Chrome Exhaust Tip cocot Appearance & Dress-Up 1 10-22-2003 08:06 PM
Found an exhaust that sounds good for V-10 1999 to 2016 Super Duty 1 07-06-2000 10:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
