Versailles 302
Not being a jackass here, but you seem to be sticking your nose into things you know nothing about. So who's the jackass ? His constant posting of part numbers not casting (or engineering) numbers is a constant source of confusion for those who are looking for specific parts, based on the numbers actually found on the parts, i.e the casting or engineering numbers The two numbers are completely different, you will seldom find a Ford part number on a Ford part. If you run across NOS parts that are in their original packaging, then the Ford part numbers can be useful, otherwise they're useless. His telling jlynn that he does not have a Versailles 302, was purely a dumb thing to do, (irregardless of the fact that these blocks were used in many other applications, which he should know, if he were truely a Ford Parts guy, and not someone just reading from a parts book.), but none the less his block is drilled in the sensor boss, which would make it a block that was actually used in a Versailles. If you have any pertinent info to add, other than criticism of something you know nothing about, please feel free to add to the conversation.
I do have a picture, I just dont know how to post a picture/dont know if I can.
Try this link, I just created a photobucket, hopefully it works:
http://i1150.photobucket.com/albums/...u/f557463d.jpg
Couple things:
1. My father in law is a machinist and says he can make a breather tube for it. There is a set screw hole that should be able to be used to hold the tube in place.
2. Where can I find the info on this engine, like the casting number breakdown, etc.? Do you have a resource that you use, or is it in your head from years of experience?
Couple things:
So ND's comment telling Jlynn that he doesn't have what he obviously DOES have in his possesion wasn't rude ? This hasn't been the first time he's "stepped in it" here. He's done it many, many times before.
Just going on know-how and years of experience.
D = 1970's decade, 8 = eighth year of the decade, V is the code letter for a Lincoln Versailles, E - it's an ID casting or engineering letter, not a part number.
"6015" is the casting (not a part) number for a Ford engine block (bare block basic Ford part number: 6010).
V as the casting letter could apply to any Lincoln, for example:
D1VE-6015-AB = block casting number for 1971/73 429, 1971/78 460, some 1979 460's.
How many 1977/78 Versailles came with 460's? None. No 460's in Passenger Cars after 1978.
Specific to Lincoln Versailles have a 4 as the third digit in the ID engineering or part number prefix.
Specific to Continental Mark's have a K as the third digit in the ID engineering or part number prefix.
Specific to Continental Sedans (RWD & FWD) have a 5 as the third digit in the ID engineering or part number prefix.
Specific to Lincoln Town Cars, Town Coupes have a V as the third digit in the ID engineering or part number prefix.
There are no Ford part numbers marked on parts after 1956, just casting or ID engineering numbers (when applicable).
Post 11: I did NOT say the OP did not have a 302. What I said was "Is it a 302?' 'These cars also came with 351W's." What's rude about this statement?
We are both USN historians, but after that, we don't agree on much of anything. Sad.
Looks like your know-how and years of experience didn't include a parts catalog.
Specific to Lincoln Versailles have a 4 as the third digit in the ID engineering or part number prefix.INCORRECT INFO HERE.
hharris8
07-26-2016 06:59 PM
86--F250
12-16-2012 10:38 PM
lakecityg
03-16-2006 03:31 PM
atdoman
10-04-2005 09:00 PM
Syzle
04-16-2002 07:55 PM
