2008 f150 power window conversion - Ford Truck Enthusiasts Forums
Old 08-25-2012, 11:57 PM
rboyd68 rboyd68 is offline
rboyd68 is starting off with a positive reputation.
converted my 2008 xl to power locks and windows. locks work great, but can't find reliable power source for windows. tried tying into stereo but blew fuses. please help!!
Old 08-26-2012, 10:35 AM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
Pull a new line right off of the fuse panel
Old 08-26-2012, 10:55 AM
thought about that. all 30 amp fuses are constant hots. worried about battery drainage.
Old 08-26-2012, 02:03 PM
danorules's Avatar
Run it with a relay off of the ignition so its on when the key is on
Old 08-27-2012, 11:42 AM
Flathead Red's Avatar
Flathead Red Flathead Red is offline
Flathead Red is starting off with a positive reputation.
What I did with mine was put in a painless aux fuse block. It has three places to tie into. One constant hot and two off the ignition. Wires right to the battery.
Red
Old 08-27-2012, 10:31 PM
thanks
thanks for the valuable suggestions. really appreciate them. big help.
2008 Econoline Power Lock Wiring vacuumbed Electrical Systems/Wiring 4 12-24-2015 09:19 AM
Crew Cab power windows and door locks. Crewcabber 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 10-15-2015 01:15 PM
power window question SUPERDUTY_08 1999 to 2016 Super Duty 3 04-20-2015 04:26 PM
Crew Cab Rear Door Power Windows Crewcabber 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-31-2015 07:18 PM
2008 F350 Window And Door Lock Problem 300sflyer 1999 to 2016 Super Duty 4 08-30-2012 03:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
