California Emissions - Ford Truck Enthusiasts Forums
Old 08-25-2012, 05:58 PM
rzorro rzorro is offline
rzorro is starting off with a positive reputation.
Kid wants a project. Wants to put a modern efi 460 w/ ZF 5 speed into a highboy. Cant make these mods in California after 72 or after 73?
Old 08-25-2012, 06:22 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Model year 1975 and older are exempt from emissions testing.
Party up with any headers, heads, and camshaft of your choice!
Old 08-25-2012, 07:50 PM
MURDOMINO MURDOMINO is offline
MURDOMINO is gaining momentum as a positive member of FTE.
as long as you swap over everything from the current 460 with 5speed, there is no problem doing it in any year thats older than your truck.... it will require a trip to the emissions refferee and they will actually certify it. chec kthe Bureau of Automotive Repair. and look into the Engine change guidelines. it is completely legit and actually would run substantially cleaner. if you have any further questions PM me as i use to work at the refferee
Old 08-25-2012, 10:25 PM
HIO Silver's Avatar
Quote:
Originally Posted by MURDOMINO View Post
as long as you swap over everything from the current 460 with 5speed, there is no problem doing it in any year thats older than your truck.... it will require a trip to the emissions refferee and they will actually certify it. check the Bureau of Automotive Repair. and look into the Engine change guidelines. it is completely legit and actually would run substantially cleaner. if you have any further questions PM me as i use to work at the referee
A vehicle already exempt from emissions (model year 1975 and older) DOES NOT REQUIRE B.A.R. CERTIFICATION for such an engine swap/retrofit.
The statement in bold above is incorrect. For a vehicle which is subject to emissions testing (non-exempt), a newer engine can be swapped into the older vehicle and be certified but an engine that pre-dates a vehicle would not be able to be certified. Meaning, a vehicle can be updated with a newer engine but the vehicle cannot be backdated with an older engine.
I've been through it before and it is a pain in the azz.
01 or 04 or none? expedition 5.4 shovenose 1997-2006 Expedition & Navigator 12 04-04-2016 02:15 PM
hello kardar2 New Member Introductions 3 11-19-2014 01:10 AM
New member from California VTRZA New Member Introductions 2 09-08-2014 12:57 PM
New from California Go Navy enterprisecvn New Member Introductions 3 08-11-2014 10:02 AM
WANTED: 1951-52 Ford C.O.E. sawyersvintage WTB - Ford Trucks & other vehicles 0 05-14-2014 06:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
