fuel line leak - Ford Truck Enthusiasts Forums
fuel line leak
Old 08-25-2012, 05:12 PM
May Bell May Bell is offline
May Bell is starting off with a positive reputation.
Cool fuel line leak
my '79 f-250 has been coughing lately. found air bubbles in fuel filter. truck stalls if I don't step on gas when she coughs/hesitates/wants to stall. there's decent pressure going directly to fuel filter but it's not very much, in the sense of pressure. otherwise she runs solid for a couple days and then acts up again. I do have a fuel leak immediatly before fuel tank, it leaks only when putting gas in truck (what's that all about?). any ideas gentlemen?
Old 08-25-2012, 05:17 PM
460 FORD MAN's Avatar
460 FORD MAN 460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
You might have a leak in the fill tube.
Old 08-25-2012, 05:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
The leak before the tank is, like 460 FORD MAN said, probably the filler tube. There are two hoses that connect the fill neck to the tank, one the actual filler and a vent line. Either of these could be causing the leak but it is probably the filler line.
Check all the soft lines in your fuel line. There are at least two (short bed) or three (long bed) or more if you have an auxilliary tank.
These neoprene hoses get brittle with age and crack allowing the pump to suck air. Another problem is it could be carb rebuild time.
Old 08-25-2012, 05:30 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
carb engines only run on like 4 psi of fuel pressure so "not very much" may be enough. You could plug one end with a bolt or something and do a pressure test using an air tank or compressor on the other end and see if you hear any hissing. I'd only put like 10 psi in it though. If the lines look rusty or the rubber lines look cracked, I'd replace the suspect looking components. fuel leak isn't something you really want to take chances with.
Old 08-25-2012, 10:53 PM
Question
filler tube, ok I'll check that and all rubber too. thx for the quick replies, I live in the hills , sorry for my slow reply. so possible leak in fuel line is allowing air in my air filter then carb and that's probably my coughing/hesitating problem?
Old 08-25-2012, 11:07 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
A good pump should be putting out right around 7 psi. You need to put a gauge on it to see whats going on.
Old 08-25-2012, 11:59 PM
JunkyardFord JunkyardFord is offline
JunkyardFord is starting off with a positive reputation.
You might have a combination of issues. As said before, the leak is likely in your filler tube. Also, it is great advice to check the soft fuel lines. It also sounds like you might need to check the carb for debris. How long ago have you changed your fuel filter? I had a truck that was sucking the fuel lines closed, due to wear and age on the old lines, so check all of them.
Old 08-26-2012, 12:13 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
You may also have tiny pin holes in your old rubber fuel line.
Small enough not to leak any fuel but large enough to suck in air.
Old 08-26-2012, 04:43 PM
Quote:
checked carb last week, and changed the needles and seat (floater was getting stuck). otherwise carb is super duper clean. I'm going with leaks in soft fuel line, just makes sense. I'm just gonna go ahead and put new rubber down there, all around. Keep ya'll updated, and thank you for the replies!
Old 08-26-2012, 05:38 PM
Good luck with it.
Truck coughs on hwy Brucemiller18 1999 - 2003 7.3L Power Stroke Diesel 1 04-03-2016 03:32 PM
Could this be a fuel delivery problem? rews2 1967 - 1972 F-100 & Larger F-Series Trucks 8 03-01-2016 05:25 PM
86 F-150 XL 5.0 Injected. FALLS ON ITS FACE. TwoToneBullnose 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 03-22-2015 08:49 AM
Stalling on Deceleration 99ExpyProblems 1997-2006 Expedition & Navigator 2 07-24-2007 10:59 PM
sputtering/coughing Tryan7 1999 - 2003 7.3L Power Stroke Diesel 2 05-23-2007 09:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
