2007 wiring diagram
on
2007 wiring diagram
does any one have a wiring daigram for a 2007 4.0 ?
Specifically, I'm looking for the passenger side upstream O2 sensor color code.
I damaged the harness connector while reinstalling the transmission. I cut off the harness connector and it got thrown out, I picked up a new connector with a pigtail on it from Ford but the color codes are different.
I have a Haynes manual that is useless for schematics. I've searched the forum with no luck.
Can anyone point me at a schematic?
thnx,
frank
thnx,
frank
here, should be HO2 11. http://s1263.photobucket.com/albums/...ps1b269214.jpg
How the heck do you post pics right here anyway?
on
Thanks guys, I did end up getting a schematic from Partsource but I had to go ino the store for the print out.
I hooked everything up, codes cleared and all was fine for a while, then the CEL came on.
I don't remember the code as I cleared it but the description was "sensor stuck on lean"
Going to check it out now.
looking at the data from the sensor I get:
O2 Sensor 1 Bank 1: 0.04v @ 66.4% s.t. fuel trim
compared to :
O2 Sensor 1 Bank 2: 0.735 @ 7.8% s.t. fuel trim.
Sensor 1 bank one is the one I rewired.
I'll figure this out.....
frank
compared to :
frank
